All the current ones once you apply the new bios supplied by Evga :
https://forums.evga.com/m/tm.aspx?m=2858793&fp=1
FTW3 will have an even higher PT.
Ya I am glad I went with the FTW3. It will have 373w power limit from factory.
@ smffy
Like the copper look WC
Would these fittings have been a better choice flow wise?
https://www.wolseley.co.uk/product/-p512288-44/
Cheers bud
Edit interesting only for the gaming pc not the windforce yet. I will keep eye on this . Definitely cancelling if gigabyte keep the power limit gimped on their windforce
(page.3)Worked fine for this guy
Hi thanks I double and triple checked . Unless I am being incredibly thick (more than possible) that bios for the windforce is the factory one linked there to help a chap unbrick his card that he put the wrong bios onIn that same thread they released for the windforce also. A few pages in(page.3)
(That said Indo not understand why the gaming pc ti bios should gimp the windforce if installed on that card)
Sounds pretty good, which one you got?2080 Ti owners - What are your cards boosting to at 'stock'?
For instance mine goes up to 1935Mhz during Forza 4, and (i think) 1890Mhz during Shadow of the Tomb Raider.
No extra power/manual over-clocks - This is literally doing it automatically.
A rather ugly looking Palit GeForce RTX 2080 Ti GAMING PRO 11GB OC!
I thought those who've been tinkering with Turing have said that even if you exceed power limit, you're already hitting the Hz ceiling of the clocks anyway? So it's not going to achieve much by pushing more power?
