Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
I realised you meant memory cards after I posted it too.
Can't see why you would want or need it tbh. So little gap between 70 and 100 and the 100-400 is razor sharp.i have only 24-70GM, 100-400GM. debating the 70-200 GM .
yea mainly for sports although look what the 100-400 can do..Can't see why you would want or need it tbh. So little gap between 70 and 100 and the 100-400 is razor sharp.
That's why I have never bothered with the 70-200 plus I even have the 85mm to fill the small gap.
Only reason I can see for the 70-200 GM is if you need the f2.8 for sports
Enjoy your lens. Great choice in cameraA7III now ordered so hopefully have it next week and can make use of the lenses and memory cards now queued up.![]()
Did you order from Pana moz?A7III now ordered so hopefully have it next week and can make use of the lenses and memory cards now queued up.![]()
No they don't have stock and don't know when they are getting them back in, ordered from instashot-store, not heard of them before but seems to be the same sort of setup and they have a good rating on TrustPilot (plus credit card used). If they can't deliver by mid next week I'll just order from the UK with next day delivery.Did you order from Pana moz?
Which sigma lens are you referring to when you say it's sharper than the 24-70GM?I still kept looking at the 100-400 but bought the sigma and 1.4x Tc first to see if either would save me another £2500.
The sigma is sharper than my 24-70 gm and the 70-200 gm with the TC. As for focus speed, the only thing I haven’t tried is bif but yesterday I used it from 300 to 600mm, never missed a shot and it was no different to my other lenses focus speed wise (it was poor before the updates though). Yes it’s heavy but I got the sports version with sigma TC for £500 so it’s saved me a few quid. The mc-11 came bundled with the A7Riii too so it’s a cheap combo for the amount of use it will get. By the time I sell on the TC it will be a £350 lens and I now can’t justify the extra for a 100-400 over that.
