Silverstone FT05
Gigabyte RTX 2080 Ti Windforce sounds like dishwasher.....
You’ve just been rinsed by Nvidia![]()
The FT05 is a vertical case with air input at the bottom, the card mounted vertically, and the air outflow at the top. It makes use of the fact that hot air rises. Plus I don't get GPU sag.
I get what your saying but as I pointed out heat naturally rising won't matter, having no moving airflow means your passive cpu heatsink is acting like a radiator does in your house, you could set up a slow fan speed for the case fans that you can't hear that would make things a bit better, but if you don't want to you'll just have to live with the noise
I don't have a problem with the fan kicking in; I do have a problem with the noise it makes when it does.
Welcome back. Do you have an update on the bios for the windforce?Hello,
I had some time off last week and stayed off all things digital. I will check if this should be happening and get back to you. Sounds like it should not be doing that.
What orientation is your card in?
Thanks. The noise isn't as loud now which makes me thing something is rubbing and gradually wearing away. Ironically this makes me more concerned.
Vertical.
I think the orientation is a red herring I have got the 1080ti Windforce and previous to that a 980 Windforce in a FT02 - same orientation, just bigger and it runs fine, no noise problems.
My Gigabyte 980 TI manages this fine, so I know it should be possible. I'm guessing something's icky with the default GPU BIOS fan curve and hysteresis setting? I don't know. I have proof of purchase and everything - I'm in Australia.
