Wow someone actually tested with over 1400mhz on a Vega64.
Remind me what is the "normal" boost clock on a "stock" Vega 64?
There is a huge untapped performance still in the card. Whole sections of it are not used currently yet nobody knows what they are about.
Once Raytracing starts getting used for games it wouldn't surprise me to see Vega faster than the 2070 in that as well! lol
I'm looking forward to seeing what The Division 2 turns up (performance wise)...
I'm sure i saw you say you would try for 28k a few posts back. Dooo eeeet!
This may sound like a stupid question but if I want a vega 64 and then watercool it in future, I need a reference card or aib which uses the reference board?
Alphacool was going to release one for Red Devil but unknown when.
Nitro, strix and reference have waterblocks.
Either by EK or Bysksy (using it on Nitro, great product). Alphacool was going to release one for Red Devil but unknown when.
Awesome, thanks! I’ll try keep an eye out on a deal for either of the above
Do you use the lc bios Tony? What advantages does that give over the 64,is that how you get such high hbm?
I am in the process of getting a liquid, if I do so might sell the Nitro and water block. **
Please use the MM you choose to sell your items - thanks
Are any of you that have your gpus under water using liquid metal between the die and waterblock?
Did you bench before using LM and if so did you notice much of a change in temps going from paste?
Oooh, maybe LM is the silver bullet to 28kNope
I'm just joking about the 28k btw, you do you.![]()
