What "man jobs" have you done today?
1 Aug 2003
Cheshire
Finishing off my patio, and built myself a new step out of reclaimed Stock brick, and spare indian sandstone and resin grout. Cost me about £5 to build :)
13 Jan 2004
Finished boarding big wall. Particularly happy with the pipe and soil pipe cut outs. Measured about 10 times and used a cardboard template too. Soil pipe cut out could have been a little tighter but it comes out of the wall on a gradient.
Boxed in basin waste and started building framework for the counter top sink.
24 Mar 2006
Top work! Cue a load of questions:
What is that metal framework you've used to stud out the walls?
What was the insulation you used?
What depth of insulation did you insrall?
I think I am going to be doing something very similar to this.
I'm certainly going to need some insulation. It is a first floor extension out the back. Three external non cavity walls, and I'm dubious about the insulation in the loft space. I haven't had chance to check yet as I will involve climbing up and removing some tiles to see. The extension is inasessible from the main loft.
13 Jan 2004
It's British Gypsum Gyplyner Universal. Its designed to stud out uneven walls using standoff brackets. Very easy to to work with but I recommend reading the white papers and installation guides.
50mm insulation. Rockwool acoustic to the board the window void and thermal insulation which is Actis Hybris (shiny stuff on external walls). Both in 50mm as I don't want massive intrusion onto the floor space. I'll be honest I didn't heavily research the insulation as I was in builders merchant at the time time and just needed it bought. It's what they recommended however.
The Hybris is much nicer to work with than fibrous materials. Stanley blade and cut it, no itchiness and debris to endure. How it compares to the completing products I've no idea though!
20 May 2007
Few jobs over the weekend
Swapped out a light switch in the lounge- old white plastic one
for a new brushed metal one
Also hung a few pictures
Then did a bit in a room I stripped out bak in February :O
So, back in feb, it looked like this
And I stripped it out and right back
It been like that (aprt from taking the gripper rods up and filling some cracks) since ....
This weekend I painted it through and then fixed some MDF sheet, routered to look like T&G to the one wall and painted the lot
Going to form a cupboard at the end, then a long coat hook rail along the cladded wall, new light, metal light switch to match the lounge and on to the next room ...
Caporegime
13 May 2003
Warwickshire
Good work.
I always find it interesting how people seem to want to make a feature out of their light switches and power sockets. For me, whatever most blends in with the surrounding decor and minimises the impact is the winner. Guess it's just one of those taste things, but the ideal for me would be that they're invisible (notwithstanding the practicality aspect of that!).
20 May 2007
Thanks chaps :)
@Sin_Chase the faceplate has a plastic liner on the rear
Good job really as there is no Earth cable .....
@Participant - the old one really needed replacing and thought we'd try this one - I like it, the Mrs isn't sold yet, could go either way (I.e. Until she tells me it's ok or swap it :D)
13 Jan 2004
I meant the light switch itself.
I'd check it's double insulated or at least have RCD/RCBO protection on the lighting circuit.
Double Insulation logo looks like a box in a box.
Without either of those protections (Doubled Insulated switch/RCD) or direct earthing a metal light switch can expose a live current directly to the faceplate in a failure situation..... Nasty!
To clarify you shouldn't have to rely on RCD/RCBO tripping for the protection of an unearthed metal faceplate. It's just a whole lot safer in worst case scenario than a circuit with no RCD/RCBO protection.
25 Feb 2009
Built 6 IKEA cupboards.
Garden maintenance.
Need to take the render off my bathroom wall. Looked at it and decided I'd do it next week:)
Not sure the best way to get it back to block other than bashing with a hammer and chisel?
20 May 2007
Thanks, I can't see anything on the switch itself - I have anogher sealed one somewhere, ill look on the packaging, but the entire inside is plastic lined (including the "clear" bit between the grey connectors and the edge of the switch
Have RCD as well
24 Mar 2006
Lovely stuff! Thanks for the info. I'll be able to board out two of the three external walls
The door has probably 10mm clearance from the frame to the adjoining wall. This means that any kind of boarding out will be a no go on this wall. Does anyone have any ideas how I can improve the thermals of this wall? As per lovely diagram:
4 May 2007
West Midlands
Is it an internal wall? Then it won't need insulating.
Also looks like your door swings the wrong way?
You could replace the door frame?
28 Feb 2015
Then did a bit in a room I stripped out back in February :O
So, back in Feb, it looked like this
That has to be the smallest(narrowest) room I have ever seen, especially with the fuse box and assorted switches behind the door and a radiator in there too. What was it used for ?.
Good job though, much better than it was
20 May 2007
Thanks :) and, lol, yes its like 3.6m odd by 870mm (one of the reasons for using 9mm cladding rather than a frame and traditional T&G!) :o
We only moved in in May last year and it was just a bit of a dumping ground on that built in shelf / cupboard, but you had to walk in sideways like a crab to use it so very imprtactical. I think the (elderly) previous owners installed it but god know what their thinking was and what they did / used it for .....
Bought the frame / lining today so hoping to crack on with the cupboard / shelves so we can then measure up for the long coat hook rail and get it finished .... :D
24 Mar 2006
It is an external wall. The N E and W walls on the diagram are external. And yes, you're right, the diagram is wrong in that the door does swing the other way. Still, the door frame and door opening is too close to the wall if I wanted to put some insulation in.
And even if I did manage it, Id have to plaster the boards so I could do some painting as I wasn't planning on tiling that wall entirely.
18 Feb 2003
Brighton/West Wicklow
Finally tested my outdoor lighting and i'm very pleased. Best part of a years work (including other bits).
Looks very bright in this pic due to the duff phone camera but the above pic is more representative. We were after a more mellow, welcoming glow.
