Hmmmm.... getting thisblack and white dot effect when my PC wakes up... any ideas? Driver or card?
https://imgur.com/a/TZIIu0V
We can only see 1 image....
Can you test it with another monitor to be sure it's not the monitor?
Have you fully shutdown the PC? Do you use 18.10.1 oct18? Do you use HDMI or dp cable? Are these cables rated? Have you used ddu to remove all previous drivers?
I'll give it a go, but my monitor has been rock solid since I bought it. Although that was a while ago.
It's been shut down fully, using 18.10.01 and DP cable. The cable has never given me trouble before but I'll see if I've got another one to try. I'll give DDU a try as well.
Did you upgrade to Vega recently? And when you did so you had issues?
a) DDU
First use DDU to whipe all GPU drivers from your system, in windows safe mode. Including the AMD and any previous drivers (Intel & Nvidia)
The use CCleaner to fix the registry. There are going to be hundrends of driver records left there.
Then install the latest drivers
b) DP Cable.
You need DP1.4 rated cable (no point to buy DP1.2 these days). Like the Club 3D Display Port 1.4 HBR3 2m one. It only costs £12.50.
Okay, it's a brand new Vega, installed the night before last. I've noticed the error a few times when the PC comes out of sleep, black and white noise over the image for a few seconds and then it rights itself.
I've just used DDU to wipe everything and reinstalled freesh drivers and the problem was still there. I didn't use CCleaner though, I'll try it again.
Would an older cable show the image correctly afterwards, or would it be a constant problem. Not sure what cable I'm using, I'll check...
EDIT: I'm using a DVI cable
The Nitro or Reference?
I was looking at the Nitro with a benq 144hz monitor and a new case!! might as well get a better psu while I'm at it lol.
Do you plan to watercool?
Out of curiosity would a buyer not be better buying the cheapest 64 they could find to watercooling rather than one with arguably the best cooler (and most expensive)Do you plan to watercool?
It's a choice between a RTX 2080 or Vega 64 plus 144hz freesync monitor.
And have some money to spare![]()
Ah nice one. Thanks for the detailed explanation my good man. I’m just trying to gather as much info on vega64 as possible. Really want to jump on board but keep ‘himming and haaing’ - missed the Red Devil deal with all my assing about.Depends. The only cards you can buy "new" are Strix, Nitro and Red Devil. You cannot buy reference card "new" any more.
From the three above the 2 guaranteed having block, are Nitro & Strix.
The "most expensive" is kinda null and void argument. Strix was the most expensive, yet it has engineering issues, and the VRMs aren't getting cooled, resulting to performance worse than the reference card.
True you can fix the card by replacing the thermal pads with thick 3mm ones, but out of the scope.
Next one up, the Nitro was/is more expensive than the Red Devil, but both perform the same regardless the price.
Bottom to the rack is the Gigabyte one, cheaper for quite some time now, but the cooler is sub par and doesn't have waterblock for it.
Then is the used market if someone wants to delve into the great unknown.... I was lucky the second Vega 64 bought last week (reference), was brand new (i was surprised tbh) , but there are many from ex mining rigs having received a heavy punisment (the HBM), and many are flashed to mining bios.
The nitro looks tempting but I’m pretty certain with the nitro card I’d need to replace my psu (asked previously in this thread about it in relation to the Red Devil and the consensus was ‘probably ok’)
Ultimate plan would be to put it under water but only when I come to replace my zen1 with zen2 cpu and board.
Haha yes, one wonders who that might beIf you do not push 330W, which is not needed, and stick to Balanced mode with 1100 HBM you are fine at 2560x1440 with freesync. Most 650W+ PSU will take it.
Also rumour has it, that a watercooled Nitro could possibly go for sale in MM, if it's owner decides to stick to it's current miTX board and not upgrade to X399 next week.
