Yeah you can, Its what I use (unlocked) Its an amazing modem, rock stable. FWIW I use an Asus AC86u.
Code:
Stats recorded 30 Sep 2018 13:18:12
DSLAM type / SW version: BDCM:0xb12d (177.45) / v0xb12d
Modem/router firmware: AnnexA version - A2pv6C038m.d24j
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 160 days 7 hours 39 min 57 sec
Resyncs: 0 (since 30 Sep 2018 13:18:09)
Downstream Upstream
Line attenuation (dB): 14.1 0.0
Signal attenuation (dB): Not available on VDSL2
Connection speed (kbps): 79999 20000
SNR margin (dB): 6.3 13.8
Power (dBm): 13.5 4.4
Interleave depth: 16 1
INP: 48.00 0
G.INP: Enabled Not enabled
Vectoring status: 5 (VECT_UNCONFIGURED)
RSCorr/RS (%): 0.0335 0.0000
RSUnCorr/RS (%): 0.0000 0.0000
ES/hour: 0 0
