Oooo, is that a block for the Red Devil?It's not too bad with a block on it, but yeah still way bigger than the reference with an EK block ...
I didn't think they made a block for that card.
pics required!No I have a powercolor reference card that had the blower style fan. Now it's got the Morpheus II cooler with 2 120mm fans strapped to it. It's just a big sandwich of metal and fans![]()
Haha ok when we get back from the Fireworks I'll take some.pics required!
pics required!
holy cables and fans batman!!
holy cables and fans batman!!![]()
you need a nas!!![]()
I have way too many hard drives lol. When the window is on the case it mostly covers them so hey ho.
Yeah might look into it. It's not that bad is ityou need a nas!!
nah, if the side panel is hiding most of them it's fine, my ocd would kill me though!!Yeah might look into it. It's not that bad is it?
You know when the PC was being built I was super happy with the cable management at first. Then I started installing the drives and yeah, it all went to ****nah, if the side panel is hiding most of them it's fine, my ocd would kill me though!!![]()
Huh I never thought of that. I'll give it a go cheers.An advice...
Turn the HDDs to the rear and connect them from the back. That way all cables will go out and from behind to the bottom. It helps to use SATA extensions here also shall you wish (around £2.5-3 each).
@Thekwango perfectly understand
haha yea, I get twitchy now and again just knowing the back panel of my case behind the motherboard is a birds nest of cables, I pop it open every month or so just to see if can tidy them up a bit more - I always close it back up disappointed!@Thekwango perfectly understand
Me too, though I'm leaning heavily towards custom cable solutions. The stock cables with products are often just inadequate.Perfectly understand. Having 25 years ongoing war with cable management![]()
https://cablemod.com/product/cablemod-modflex-right-angle-sata-3-cable-30cm-blue/
Can be done, but they are a pain to do manually and costly to buy in![]()
