Did you RMA your 20XX card, if so please post the details.
Man of Honour
21 May 2012
The GPU Desert
Please use this thread to post as much information as you can about any NVidia 20XX series card you have had to RMA.
I will link the posts in the OP.
2080 Ti Faults
Date 18/03/2019, Card 2080 Ti, Vendor Palit, Model Gaming Pro, Problem Space invaders fault, OBH Link
Date 15/03/2019, Card 2080 Ti, Vendor Asus, Model Strix, Problem Game crashes at 2160p and Space invaders fault, whitestar85 Link
Date 14/03/2019, Card 2080 Ti, Vendor Gigabyte, Model Waterforce, Problem Flashing artefacts, game crashes and blue screens, Loz Link
Date 09/02/2019, Card 2080 Ti, Vendor Asus, Model Strix, Problem Space invaders artefacts, jdawber85 Link
Date 09/02/2019, Card 2080 Ti, Vendor Zotac, Model Amp Edition, Problem Space invader artifacts, scorchisio Link
Date 07/02/2019, Card 2080 Ti, Vendor EVGA, Model FTW3, Problem Horizontal lines across screen, RSR Link
Date 01/01/2019, Card 2080 Ti, Vendor Inno3d, Model X2 OC, Problem Great white splotches and then card hangs, bluebird Link
Date 28/12/2018, Card 2080 Ti, Vendor NVidia, Model Founders Edition, Problem Replacement card game crashes artifacts and system freezes, ArmitageShanks Link
Date 28/12/2018, Card 2080 Ti, Vendor Asus, Model Strix, Problem Driver crashes under load, Preden Link
Date 25/11/2018, Card 2080 Ti, Vendor Zotac, Model Amp Edition, Problem Game crashes and artifacts, Beeney Link
Date 19/11/2018, Card 2080 Ti, Vendor Gigabyte, Model Aorus Xtreme, Problem Playing COD, game running but no sound, scubes Link
Date 16/11/2018, Card 2080 Ti, Vendor Gigabyte, Model Gaming, Problem Black screens and game crashes, NeoVo Link
Date 09/11/2018, Card 2080 Ti, Vendor Inno3d, Model X2 OC, Problem Fans slow artifacts freezes and crashes, bluebird Link
Date 09/11/2018, Card 2080 Ti, Vendor Gainward, Model Phoenix GS, Problem Artifacts stutter and black screens, Gripen90 Link
Date 08/11/2018, Card 2080 Ti, Vendor NVidia, Model Founders Edition, Problem Game crashes artifacts and system freezes, ArmitageShanks Link
Date 06/11/2018, Card 2080 Ti, Vendor NVidia, Model Founders Edition, Problem Drivers crashes and error messages, ltron Link
2080 Faults
Date 08/11/2018, Card 2080, Vendor Gigabyte, Model Gaming OC, Problem Black screens and USB faults, gwailo Link
2060 Faults
Date 06/04/2019, Card 2060, Vendor NVidia, Model Founders Edition, Problem Unusual fan rattle, Double07 Link
Date 16/03/2019, Card 2060, Vendor Palit, Model StormX, Problem Random black screens, Charlie Bravo Link
Date 14/03/2019, Card 2060, Vendor Gigabyte, Model Windforce, Problem Bad fan rattle and erratic speeds, chickadee Link
You will not achieve much with this topic. Most people won't even see the post never mind comment and most shops do their best to point returns direct to the manufacture. Not to mention it's unclear how much of a problem this is as the cards supply is limited and they are still very new.
Why I am returning my defective 2080Ti Founders Edition:
1. Random display driver crashes in games. Very unstable with driver 416.34, initially stable with the older 411.70, but stability worsened over a few days until 411.70 also began crashing frequently to the point where I was getting eventId 13 Graphics Exception errors with multiple warp errors and shader errors. I am also getting EventID 14 'The description for Event ID 14 from source nvlddmkm cannot be found' errors on every boot too.
2. Randomly I'll hear the USB disconnect sound and I think it's due to the USB-C VR port on the card.
3. The LED logo will randomly turn red or go off entirely, other users have reported that this happens to them in response to GPU temperature changes and some have said it's permanently in that state from the factory. This would suggest an electrical problem with the card to me and may give some clues as to what's happening.
See: https://forums.geforce.com/default/...20-series/rtx-logo-leds-won-t-turn-back-on/1/
and https://forums.geforce.com/default/topic/1073171/geforce-rtx-20-series/rtx-2080-logo-is-red-/
4. My Palit GTX 1080 Gamerock Premium has none of the issues reported above.
System specs:
i7 [email protected]
Noctua NH-D15S CPU Cooler
Gigabyte X99 SOC Champion Bios F22
32GB Kingston HyperX DDR4 2133MHz(4x8GB)
Nvidia Geforce RTX 2080 Ti Founders Edition
Corsair RMi 1000W
Dell S2716DG Gsync 2560x1440 144Hz
Windows 10 Home 64Bit 1803
Phanteks Enthoo Evolv ATX Case
Samsung SM961 512GB NVME boot drive + Samsung 840 Pro 256GB SSD secondary drive
UEFI boot with CSM disabled and Secure Boot enabled.
I've RMA'ed my Gigabyte 2080 Gaming OC.
Everything started off ok but after a while the PC would go past POST start loading windows then I'd be faced with a black screen this would happen with every cold boot. My USB devices would have no power going to them and I would hear the USB disconnect sound like Itron. Leaving the PC on at the black screen for a while would result in the GPU fans running at 100% at which point a reset of the system would allow me to get into Windows with everything seemingly ok till the next cold boot.
Replaced my PSU made no difference.
Sent the card back to Overclockers to be tested and now it's in Gigabytes hands awaiting repair / replacement.
Slightly annoying as I've got some freelance work on standby as the old 970 I have struggles with Substance Painter.
2080Ti Founders Edition, S/N 03238...
No GPU O/C applied.
Games were crashing to the desktop spontaneously.
Then a couple of days later, artifacts and system freezes/restarts during games and benchmarks.
Then a day later artifacts and freezes on desktop after boot.
Then a day later, boots into a blank screen and hangs.
Card removed after 8 days.
RMA took 16 days.
Replacement S/N 03242...
No issues so far after one day of use, but we shall see.
You might want to have separate posts for 2080 Ti, 2080, and 2070 RMAs.
I have planned for that with some extra posts at the start of the thread.
If we see a lot of faulty cards it will only take me a few minutes to separate them into lists for each SKU.:)
Well my Gainward RTX 2080Ti Phoenix Golden Sample which I got monday this week also decided it wanted to be RMA'ed. Suddenly today wanting to game, it would display star flashing like artifacts in all different colours - looking like something on a christmas tree, and afterward the image would stutter to a halt and the then black screen, and then only a hard reset would get me back into windows. The card has now been packed and I'm awaiting an RMA number....
My wifes MSI RTX 2080 Duke OC knocking on wood still lives.
Sorry to hear about your card.
List updated.
Inno3d 2080ti x2 OC
Ran for 4 days - reached 84-85c in games but fans never went to 100% -= stayed about 50%
5th day or so, began to get random coloured blocks on the screen and the game freezing or giving Fatal DirectX Error 11000002
6th day, PC began to reboot or shutdown during games. Between reboots, large areas of screen turned into minecraft mess of coloured squares.
