- 11 Sep 2013
NVM
Which is even more reason to revisit legislation on how bright lights actually are.
I think a lot of the disputers ignore factors like the light intensity. Militaries are still using red light, as do quite a few trucks and other work vehicles needing internal illumination. Yes, a bright red brake light will wipe out your NV, but a dim 20 lumen torch won't do that anywhere near as much.
Xenons and LEDs do provide awesome light if you are only worried about looking just in front of your car, yep sure its like day there, but as its so bright the cut off feels far more marked
per previous discussion , eg. below, they are not allowed in usa yet because their regulatory boards a bit more diligent than EU :That's not an issue for systems like multibeam. Once tech like that trickles down, any perceived cut off problem will go away.
Sorry, I'm old and drive an absolutely ancient car from, like, before WW1, innit.... I had to look up Hold Assist. I don't think I ever want a modern Audi, after reading that!!
Sounds absolutely pointless and more like a second electronic auto-handbrake.... Still don't want one.
Honestly its one of those things that sounds like it would be a pain. Once you have used it for a few days its horrible going back to a car without it. But there is nothing about it that requires you to do anything normal than driving as if it doesn't exist should you choose.
It operates as soon as you come to a complete stop with the brake pressed still. Its on lets say after 1 second. So I pull up to a junction, say from a side street, it will engage. Now I can lift off the brake with no thought to if the car will try to move forwards or backwards, and decide if I want to keep the clutch engaged and hover ready to press the accelerator pedal, or if its going to be a longer wait and I may want to take out of gear and lift off the clutch. Assuming I dont expect a long wait and decide to leave in gear, I am now hovering over the accelerator pedal, as soon as I start to press that the brake goes off.
On an Audi you do, yes...
But my old 1996 Mercedes would 'hold assist' without the need of an electromechanical 'hand' brake at all......
Both of which I can already manage perfectly well, even on hills.
Might just be in how you've explained it, but I haven't seen how this is supposed to be superior... It's been a feature of all the automatic gearboxes I've ever driven, bar the crappy CR-V.
What does it add, then?
It may do something differently, but what does it actually add?
I generally find most recent technology in vehicles does more to disconnect the driver and divert their attention away from the drive, than add any particular benefit...
I also find an over-reliance on features like this makes people very lazy drivers... and often very tight-fisted ones when they end up bringing in the broken features to be fixed.
So anyone with an auto box?I wish they'd do something about the amount of idiots who sit on their brakes in queueing traffic dazzling anyone behind.
OK, just HOW many flippin' hold assists do you kids need on a bloody car, here??!!
Have you got one for when you need to just nip out to the postbox at the side of the road, too?
As does the handbrake... and for more than just a few moments.
Then I apologise for not being able to understand what your wording has failed to explain...
Given how you mention a clutch, I assume you also have a gear changing control of some kind? Why then do you not have an automatic gear change hold assist, to actually free up this now freed-up hand that is not actually freed up by this device, because you're still using it to take it out of gear as you suggested.....?
Tip, I am in effect
What on EARTH do you need a free foot for, anyway? Tapping along with the radio?
Is it really that much of a hassle and a struggle and a life-threatening issue to just apply a handbrake?
Do you also struggle when you have to indicate and don't have a free hand for that?
Do we need to get Jeremy Kyle out to mediate between you and your vehicle during these difficulties?
The only purpose this thing seems to serve is pulling off from the lights ever so slightly faster, which again comes under lowering driver standards and abilities, or as a disability aid for those with impacted or missing limbs that they cannot otherwise co-ordinate like most normal drivers.
Then again, I suppose driving a BMW or Audi should now be listed as an official disability....![]()
Utter tosh.
None of those drivers should be riding the clutch in the first place, but technology cannot replace that.
Well I have already told you.........
But to further that, I have watched people I previously knew to be pretty good drivers and seen their standards lower as more technology like this crept into their cars. It's not age or anything, as their standards jump right back up the instant they drive my 'old' manual car.
Introducing more tech to do what the driver should be doing doesn't increase driver standards. It actually lowers them, as they start assuming the car will do everything for them... that's actually another excuse I'm hearing more often from people with broken vehicles, too.
Eventually this will just make human drivers obsolete and you can kiss goodbye to your driving licence.
Do auto boxes not come with Neutral or Park settings, any more?
Well, it sounds like they come with a dozen different auto-brake mechanisms now, so the lights should still go off after a couple of seconds anyway...
