- 30 Mar 2010
- Exile
Jebus, the wheels on these get dirty.
Hmm, OEM pads aren't that dusty? Rears tend to be worse than the fronts in mine lol![]()
VSC keeping you on the straight and narrow probably
Or, sticking rear caliper. Not unheard of.
Well the good news is, it's only a small number of early 2012/2013 cars that are affected. The bad news is, mine's one of them.
But, every cloud has a silver lining. It was due for the 60k spark plug service next week. I've agreed with the dealer that I'll just have a normal full service and then when the recall procedure work is finalised and starts in December/Jan that I can have the spark plugs then to save on labour charges.![]()
How did you get informed of yours being affected?
Ran mine through the Toyota website which says I have a voluntary recall but doesn't clarify what for.
As far as I'm concerned they can take a long time deciding what they're doing. Mines scheduled for the spark plug change in September. It would be best to do the fix and service at the same time.
Take a photo of the engine bay![]()
