- 7 Jul 2008
- Newcastle upon Tyne
I have just buit a mini ITX system using the Kolink Satellite Plus case - https://www.overclockers.co.uk/kolink-satellite-plus-aluminium-micro-atx-case-black-ca-02f-kk.html
The stock AMD cooler is anoying as it ossilates and hums which, looking at reviews, is what others think.
Therefore afrer a replacement that quiet when the system is ticking over.
Max height, according to the blurb is 165mm
My initial though was somit like this - https://www.overclockers.co.uk/noctua-nh-l9x65-low-profile-performance-cpu-cooler-hs-032-nc.html
I've head the advantage of blow down is cooling to the RAM
I want it to be furture proff because I know, at some point, I will play with overclcoking
