- 5 May 2017
- Oxfordshire
U must have fans spinning moreMines must be faulty then cos mine sits at 33 idle lol..
I can now Confirm that mine stay too at 34C when idle and all case fans up 100%No mate it’s on default .
So I ran the Scanner on Afterburner (X1 kept crashing) It gave me a result of +149, however I keep getting crashes/driver crashes where there is no signal to TV but pc still on and fans spinning etc. I have even dropped OC to +80 With max power and temp and still had a crash after 30mins on FFXV.
Also how/where does the GPU bracket sit? The only picture in the box I seen implies it just a stand to place the GPU on a desk unless I totally missed it haha ??
Registering for that year Warranty ASAP before I forget as well.
Thanks,
Sean
Ok my views on this card are well built nice wee orange connectors over the hdmi ports wee stand that holds it up ( nice touch gigabyte ) can’t see the rgb cos my pc sits on the floor lol. Over all the card is really exellent can’t fault it yet all my games are smooth as silk as I’ve said. Before I bought this card for pure speed and NOT the ray tracing any off this tech.
Fair enough. Will try rump
Up mine![]()
Yields could be better!
Simply demand far outweighs supply and the supply generally is very low as NVIDIA can’t make enough.
Suspect it will improve Q1 next year.
It goes inside your case to support your card mines is in lol.
Hows the temps and fan noise so far?
