***** AORUS DID NOT INVENT THE GRAPHICS CARD, THEY PERFECTED IT! RTX 2000 SERIES!! *****
Now the faults are starting getting game crashes COD ww2 to no signal on tv . Temps are fine I hope it’s a driver issue .
Same here, was getting crashes 'no signal on tv' I even took the CPU OC of this morning and managed to play for 1 hour without a crash. I then applied a small OC to the GPU and crashed after 10-15mins to desktop this time though.
I have started a thread on it. Getting suggestions that my PSU is under powered, obviously yours is not. I will reset all OCs again now and see if I get a crash (need to run for 1hour plus really)
Does it says anything when it crash??
Yes its mine.
Your own product listing on the bay states :
Item specifics
Condition:
New: A brand-new, unused, unopened and undamaged item in original retail packaging
You've listed your card as "unused and unopened" and you've even took a photo of the yellow security seal in your product pics, to give the impression it's "brand new and unopened".....yet you're clearly using it in your system, opened and currently being used.
Wow, that's as snide and deceitful a thing as I've seen in ages. At least have the decency to mark it as used. You're clearly trying to stroke any buyers by pretending it hasn't been opened at all.
No, I just loose signal to the TV. PC stays on and fans continue to spin. I have removed all overclocks on CPU and GPU and it seems fine now, so I have gone ahead and ordered a 1kW PSU with a 10 year warranty, hopfully this will sort me out and be able to OC both and get full performance again.
I haven’t OC my card but wot you said that’s wot happeneds to me also.
I had this issue I used Display Driver Uninstaller to remove the driver and reinstall the latest driver and it has been fine ever since.
Also done a time spy run after Ocing my card https://www.3dmark.com/3dm/30402412
You are right. It has been updated as being ‘Used’
