Ebay mate.
got my bottomless Portafilter (in 2008!!!) from happy donkey
Not even that, just for inspecting your technique while learning really.Is this good?
and what is the advantage of them? I always thought they just for pulling pretty looking shots.
https://www.ebay.co.uk/itm/Bottomle...le-Gaggia-Classic-Coffee-Machine/162378179782
Some argue that the coffee flow is less molested by spouts and retains more bubbles but hey, if that's good enough for the professionals ...
Now THAT is a reason I'd buy one!yup, although I tend to use mine all the time as it means i can fit a good size mug directly under the pf![]()
Here's a reminder of how it works
- Buy one get one at 25% off
- Discount code not required
- The offer will automatically apply to the lowest value items in the cart
- This offer excludes green coffee and coffee subscriptions
- Offer valid on Friday 23rd & Monday 26th November only
Can the Barista Express be had below £400 at the moment?
The blind portafilters a bit difficult for charging&compacting uniformly though I find .. you have no spout to rest on
Get yourselves a tamping station
On Amazon it is at £403.20 currently
for all PF's they generally have some dribbles, after pre-flush, so mine is usually in worktop middle above a (clean) dishcloth ....Personally i'd say its easier as you can easily lay it flat on the edge of a counter top
prices may drop more with the new models, watch the coffeeforums deals threads ... faster than we areTorn now between this and the Duo Temp Pro
