Thanks, would that include a POE unit?£150 vs £125 for the Pro if you buy from OcUK. Pricing may vary from other suppliers.
Yes injector not unit!What do you mean by PoE unit? If you mean PoE injector, then yes, it will.
Ok thanksIf you buy a single, yes. On multipacks, no.
As far as I’m aware, the newer Pro units don’t come with a PoE injector but all other models do.
Been thinking of picking up the Pro AP. The whole PoE thing makes me nervous, as I've never dealt with it before.
I've seen some very confusing articles which say it uses the unused pairs in cat5e...but gigbit uses them all. Also saying you MUST use cat6. And that some older devices might get fried!
If I get the injector, does it just act as a PSU for the AP, basically taking in the Ethernet (plus power from the wall) and applying the power over a single connection out to the AP? Why (does?) gigabit still work if it's using two pairs for power?
Decided i'm going to go this route instead of the mesh Orbi gear, too many dodgy sounding reviews for my liking.
So is it best to use 2 of these one on each floor of a house, or will one along with the ISPs router be okay, router downstairs AP upstairs?
Also which ones to go with whats the difference with them all.
Yup, works fine on macOS.I have a MacBook Air can I set it up via that?
Anyone have the 16XG switch? If so, do you get 10GBit from all of the copper ports? I need to plug 3 ESXi hosts in and then one uplink.
The SFP+ ports will connect to my NAS (QNAP). Anyone know of any DAC cables that will work between the switch and the Intel card that the QNAPs use?
Cheers. I’ve ordered the switch and some cheap (£25) DAC cables off Amazon. The reviews say they work fine so we will see. I’ve also ordered a 10Gb PCI card for my NAS. Should hopefully all play nice together.As long as you have a Rev 11 or later switch you’ll have no problems getting 10GbE connections working. I use the genuine UBNT DACs with QNAP TS-831X NAS units and they work just fine.
How loud is the 16xg ?
