How many of you guys have had your 2080ti fail ?
As I picked up a 2080ti in my local store today about 10 times and just kept putting it back down on the shelf due to worrying from hearing about these cards failing...
None of them fail except an extremely small first wave batch of the Founders Editions
You could also try really stressing it for a few hours. People have reported that coil whine went away afterwards.Is anyone experiencing coil whine on their cards?
My MSI Duke is suffering from pretty bad whine. I can hear it over all the fans, AIO/pump and even speakers. I do have an open air case (the Thermaltake P3) but Im positive I would hear it in a closed case too.
Its so bad the card will have to go back. Ive gamed for several hours but the noise won't subside. Will give it a go in a different system/PSU, but not holding out much hope.
Obviously this doesn't work for everyone but it works for some.
Pretty normal with these high powered cards unfortunately. Had the same since the 1080's and 1080Ti's. Why i have had my case on the floor for some time now. As well as the rear of the case sealed and rear of the card foam stripped to minimise any whine so i cant hear it anymore.
It can as above get better with time. But yeah is annoying when its the loudest thing in the system.
I had a 1070 armor which had whine, but i got a bgrade 1080ti from ocul, presumably used, and it has none thankfully.Thanks both. I genuinely thought that the higher end cards would eliminate this problem, but my former 1080ti had similarly loud whine and that was an ASUS. I kept that for months but eventually became sick of the noise and RMA'd it.
Between the 1080ti and the Duke i've been using a vanilla 1070 and that has next to no whine even under load, so I don't think my system is the root cause.
Thanks
O.
Finally got my 2x RTX2080ti installed... but think I've done something dumb.
I see both cards listed in device manager... the nvlink adapter is connected... but there is no SLI option available in the control panel. And I don't seem to be getting SLI worthy performance.
How the heck do I get this working?
On other motherboards, this could happen by putting the second GPU in the wrong slot... but there is only 1 slot for 2nd GPU on this motherboard.
Z370 limitation? I don't think so... but only thing I can think of.
Should run fine on z370 I would have thought. What board is it crinkle?
I suspect you have tried the obvious DDU and reinstalling drivers?
Thanks, figured it out... PCIE NVMe SSD was knocking the second GPU down to 4x speed & that was stopping SLI from running.
Migrated to my SATA SSD (been years since I've run main OS off one of those) and it's working fine now!
I wanted the IPC of this CPU... seems i'll have to switch back to different platform to get the use I want
Dang it... oh well.
Yeah, it's not M.2... it's a 4x card... the latest optane thing... I'm sure that's why... if it was m.2 then I think it would be ok like you suggest.
It's ok... i'll run like this for now & then upgrade to the latest 18 core cpu when it's available.
Just annoying to have such a gaming limitation on the best gaming CPU :/
Even with SLI enabled... it seems to have absolutely no effect on the frame rate of BFV with raytracing enabled... so complete waste anyway
Damn you Nvidia... give me a feature I'm really excited about, charge me a fortune for it... then let it play like a pile of dog poo![]()
. Yeah that will be why.
. Why I got rid of SLI a few years ago just not worth it anymore.
Ahh that’s why I was confused. Yeah that will be why.
Wow what. Why I got rid of SLI a few years ago just not worth it anymore.
I hope they fix that as you’d expect both cards to work together with RTX cores just like SLI does normally. If it doesn’t then RTX is even worse than expected.
RTX with super SLI bridge. But RTX itself doesn’t scale in SLI. Nvidia...![]()
That's because you have to switch BFV to DX11 to do SLI, which of course then turns DXR off totally defeating the purpose.Even with SLI enabled... it seems to have absolutely no effect on the frame rate of BFV with raytracing enabled... so complete waste anyway
