Why do people chase 4K gaming?
TNA
TNA
Caporegime
13 Mar 2008
Greater London
Come on now, 60fps is perfectly fine when using a mouse.
To be fair if he has got used to 144hz and 144fps minimums it might well feel that way to him or others. But I am guessing for the majority that will not be the case. Unless one is playing fps games mainly, 60hz/fps is perfectly playable imo, obviously unless you just got used to high fps as mentioned.
Personally I would not mind having a higher hz monitor and still play at 60fps, which imo is more than playable. Buttery smooth as far as I am concerned and at 4K it just looks so much better than 1440p :D
Playing Shadow of War right now with a controller and fps locked at 57fps as per recommendation on the blurbusters g-sync guide and the game runs silky smooth. No need to use any anti-aliasing which in many games looks like you smeared vaseline all over the image :)
6 Jan 2013
Rollergirl
i didnt say you wouldnt notice, im saying that it is perfectly fine to use a mouse at 60fps for anyone no matter who you are. Even you.....
I've got a 4k screen too, it isn't like I have no comparison to base this on. The image quality comes nowhere near close enough to making up for the smoothness of 80fps+ for me.
This thread probably needs a poll, to be fair. :)
Permabanned
15 Oct 2011
Nottingham Carlton
Well On Black Friday upgraded 23 inch 1080p IPS to 32 inch Ips 4k . Overclocked the monitor to 72hz@4k also does 1440p@144hz Who said one cant run 4k monitor at 1440p@144hz :D Not native but looks good enough for shooters if i play any.
Very happy with the Image mostly playing slow games and Desktop :D aaaa And forza runs at 72fps with no drops with vsync :)
11 Jun 2013
Nottingham
Ok so i ran some benchmarks of AC Origins last night and it was maxing out my i7 2600k OCed to 4.6 and my 1080ti.
Origins runs like a dog though. The "double DRM" (or whatever it is) makes it run kinda poorly even on really powerful CPU's. Basically I'm getting better (more consistent) frame rates from Assisins Creed: Odyssey.
19 Jan 2010
Agreed dude, ive never liked AA even at 1080p.....
Permabanned
15 Oct 2011
Nottingham Carlton
TBH thats reason I'm sticking to 60hz monitors. Once You get used to 100fps+ there is no way back. Im happy with 30-60 range with maxed details AA and stuff to kill fps :D
TNA
TNA
Caporegime
13 Mar 2008
Greater London
Yep. Much rather spend the grunt on better image quality :D
Horses for courses as they say :)
1 Dec 2006
Amsterdam, NL
This is untrue. If you were an experienced gamer on the PC scene then you would understand that its all about a balancing act, you simply cant have it all with all the money in the world so you have to make allowances here and there. I for one am much happier to have a better looking imagine at a higher resolution than continue to game at a lower resolution to gather in over 120fps at all times. Drop the console comment because you are just as close to that experience with your lower resolution!
I'm so confused by this statement, unless you're trying to run a game at 4k, 60fps is still the 'desired' fps at a minimum. 50fps may be acceptable and any lower is just a stutter/lag fest. At that point, you may as well indeed stick to console.
I game at 1440p/144hz. Whilst AAA titles and even some GPU intensive indie titles push my rig (8700k, 1080ti) to drop to the 100's and hell, even lower some times. It's still a vast improvement over 30fps...
In regards to the remark of PC gaming, been a PC gamer since I was a kid (a good couple of decades and then some). And yet I stand by my statement, the majority of people will drop settings such as HBAO/AA/texture resolution to get above 60fps. I don't know any PC gamers personally that would slap everything to max with less than ideal hardware, sit at 30fps and be happy with it. Granted, to have a top end system you need to drop a couple of grand these days. But it's a hobby... People wishing to buy mid tier hardware and expecting triple digit FPS at higher resolutions than 1080p are the inexperienced ones. You build around your resolution/desired frame rate. Not the other way round.
Again, your point confuses me as gaming on a PC at 30fps is utterly pointless.
19 Jan 2010
And I am equally confused by your statement bubby, when did I mention anything about 30fps?
TNA
TNA
Caporegime
13 Mar 2008
Greater London
Yeah I’m not neededing 4K
I’m enjoying gaming again this winter with a 1080ti and Ultrawide....My next game is Wolfenstein II looking forward to it...
Like playing Doom but killing nazis instead of monsters lol :D
It is not about needing or chasing. If one wants the best graphics, then it ticks that box. Just the same way if someone plays competitive fps and wants 240hz monitor. Maybe you should make another thread saying why are people chasing higher hz monitors? The answer is obvious in both cases imo ;)
Could not get into Wolfenstein II, but I am enjoying Middle-earth: Shadow of War, although it did take me a while to get into it.
25 Nov 2011
The KOP
Touching on frame rate I'll provide my 2 cents.
For me anything above 80fps on a 144hz monitor is a must, I can notice/feel the frame rate difference below 80fps
But I find it really hard to notice the difference above say 80 vs 140
Permabanned
2 Sep 2017
4K is probably one of the greatest technologies ever discovered by humans. Just watch 4K content on a 50-inch screen - brilliant photo-realism with all the details present.
No loss of quality, it is as if you stand directly in front of the scene and your own eyes are the camera.
Caporegime
OP
24 Dec 2005
Autonomy
Not penicillin then?
Caporegime
OP
24 Dec 2005
Autonomy
Penicillin is not a technology @easyrider ;). Plus some people can die from taking it so its not as great as you might think :D
Oh it is.
After the war, chemist John Sheehan from the Massachusetts Institute of Technology pioneered synthetic penicillin in 1957 and first used the term antibiotic. His work opened the door for the creation of different, bacteria-specific penicillin drugs. Research still continues today in the penicillin and related beta-lactam antibiotics.
