I'm not saying it's impossible, but the chances of receiving 4 dead cards must be astronomical (I've only had one duff card, second one is a keeper...so far).
Are you sure it's not something else causing these cards to die?
There is an excel file on the nvidia forums showing the failure rate at 59% for the 2080ti both AIB and FE. My 2080 is still getting those occasional 1 second black screens on the desktop and while gaming, once in 4 hours or so. I wish NVIDIA would just come out and say whats going on. Its hard to tell what is a driver issue and what are the signs of a defective card.
The file which is self reported and people reporting the same thing multiple times yes... I thought this crazy talk had gone away.
. I can just envision the rma centre piled up with wonky cards. That's quite a chunk assuming accurate numbers. I can just envision the rma centre piled up with wonky cards.
This surely has to be faulty gpu's that are getting passed out or a flaw in the wafers that went undetected.
Some people reported 2-3 failures, because they had that many. Already in this discussion there are some with 2+ replacements already.
Look at @Gripen90 how many failed cards had on both his systems. 4.
Or it’s compatibility with the other hardware/software which means the replacements also appear to have the same issue.
That’s what I said, multiple reports from the same people.
Anyway I’ll leave you all to it...
Ah, yes, typical, blame the user. Guy on HardOCP had 4 cards fail on two different computers. Kyle's failures were on two different computers. Gripen's failures were on two different computers. And please tell me how is it a computer issue when some of the guys that had multiple failures have two cards in SLI and one card works and the other doesn't and the replacement one doesn't work either.
It's not a problem with their computers.
Or maybe you think they are lying? Somebody didn't believe the guy on hardocp with 4 bad cards. He came back with pictures and proof that he had 4 cards and that they did all fail.
Or maybe you believe Nvidia saying that the RMA rate is normal. Kind of contradictory information from them. Why on earth would they come out about the test escapees if the RMA rate was in any way normal?
But, you go back and stick your head in the sand.
All I wanted was a card yes I’m not happy that I had to rma it but these things happen unfortunately but it’s been tested so I’m sure I’ll hear something soon.
Hope all goes well with the RMA and you are back up and running soon.
If there really is an inherent design flaw causing card failure and Nvidia know it exists, you can be sure they'll be in corporate damage limitation mode, first rule of which is to deny said flaw and/or deny there is a problem at all.
Second rule, say as little as possible, preferably nothing at all to the general public.
Give it a rest with the angry angry posts, as I said I’ll leave you to your whining while I carry on using my two 2080Tis.
Apologies for having an opinion...
it's fine to have an opinion, but don't sulk when that opinion is proven wrong. You are blaming user setups for their issues with the 2080ti card, that is not the case at all.
