- 2 Nov 2018
Yea they did , there is a fan module on new 4k asus 144hz to keep that cool . The problem is fan going to be very noisy so I guess it running very hot .good point, we're talking about overclocking the module here, not the panel, is there other example in the non-ultrawide panels that use overclocking of the module? I read this: http://www.tomshardware.co.uk/forum/id-3123327/sync-issues-1440p-144hz.html
which I am not sure is relevant in that case, did they upgrade the modules since then?
It depends of monitor constructuon as well . I was reading alienware going to heat up quite a bit because it even has built in PSU . The only way is to check from time to time if monitor goes hot at the back and make some breaks to keep that cool .
