Very nice. Do you have the truck still?
Still have my F150 yes
but dont think i will for much longer will more than likely downgrade to a older American truck maybe 1995 silverado or f250Very nice. Do you have the truck still?
but dont think i will for much longer will more than likely downgrade to a older American truck maybe 1995 silverado or f250So I did just put a deposit on this
http://www.bowkermotorgroup.co.uk/ribble-valley/used-cars/car-details/PK64NGX
Should get it next week, will be my daily
I've had a look (gf sent the pic) and I can see the sensor still attached to the cables within the bumper.Is it gone completely or just pushed in? With a bit of contorting you can reach it from underneat and try to push it / re-seat it back in. I have had a similar... moment and it's now sitting 1-2mm deeper than it should, but the principle of "good enough" took over.
Weak. CBA faffing removing the bumper. Is there no access if I remove the rear wheel and/or rear wheel arch lining? It's an Avant if that makes any difference.Bumper off job is likely, you'll want to look at the condition of the clips for the sensor if it's managed to push itself in.
That said, C6 bumper off isn't particularly difficult, I fitted sensors to mine and it took around 2 hours (and that involved the cable routing and drilling the bumper!). You will need a 2nd person to take the bumper off though.
Hello,
We’re after a second car and have been looking at MX5s but have since ruled it out because of the 2 seats. My wife has now decided that she wants an Audi TT coupe (mainly because she likes the way it looks!).
For my £6-7k it looks as if I could get something around 10 years old with around 70,000 miles. There doesn’t seem to be much price difference between the 2.0 or 3.2.
Anyone have one of these? Any advice?
Thanks in advance
Hello,
Thanks in advance
10 yr old kids or less would probably be OK. Anyone older, especially teenagers... not going to work.It would just be for bundling a few children in from time to time for short journeys so hopefully shouldn’t be too bad.
Never driven a Mk2 TT, but having driven a number of 2.0TFSI cars on the same platform, as well as owning a MK1 3.2V6, I just can't see that being true.3.2 v6 sounds good but is n/a so doesn’t have the same feeling as the 2.0 TFSI.
I’ve not driven the 3.2 but most people say the 2.0 TFSI suits the car more
