- 5 Sep 2011
- Surrey
Neither is perfect. In an ideal world we would have absolute transparency from Intel and this conversation would be unnecessary.
Having seen people quoting different vcores from cpuid, hwinfo, bios, underload, with llc x on board y or z I find it hard to take any meaningful info from the stats people post.
Not to mention the inherent bias towards people with decent silicon posting vs those with poor clockers remaining silent.
Gathering a range of vcore to use from that quagmire of settings and willy waving is less useful, imo, than taking a large scale controlled test and using common sense to make reasonable assumptions.
But this is only my opinion and as you point out, the stats from silicon lottery are not a perfect representation either.
They release the info and I'll continue to post it since i think it is useful. But i agree, that it is limited in what it can tell us.
Yes, the stats are still useful. however, always good to keep in mind that vendors needs for unconditional stability are different to those of gamers, for example.
SL will only be drawing readings from CPUZ, they won’t be pulling readings from the socket. So your comments about other users doing the same being unreliable <CPUZ> is misguided.
The point of this is;
1. More CPU will be 5GHz capable than the stats are dictating
2. VID range is quite large between samples
3. Setting a global AVX offset also limits stat scope as some CPU will require more voltage than others for light and heavy workload, meaning a higher offset may be needed.
4. Load from Prime95 with AVX is not indicative of majority of real-world workloads both in terms of stability and current pulled
