- 3 May 2007
It absolutely is crap and I never normally buy into these things but am going to make an exception for resi 2. Hearing that music in the main hall again will be awsome.
Did RE7 eventually get UW support? As I recall a lot of people being frustrated it was not working even a month after release, while I had already completed at 4K no problems
Not long left now. Starting to get excited. I wonder if the PC will get the 30 minute demo?
Lol. So 60hz is not a stutter mess after all then?Ive just remembered, when i tried this in 4k, where it was perfectly in fullscreen, with no black bars, i had my Radeon settings set to Supersampling, for the AA method, with 4x AA set, as im playing Dead Space at the minute using those settings, so i turned them off and fired this back up, setting it to 4 again, and no more stuttery mess, runs fine now, even if it is only 60hz, so i should be able to play this one in 4k fine too.![]()
Lol. So 60hz is not a stutter mess after all then?![]()
You should fire up a fps counter to see if fps is the issue. As if you run it at 60fps it will be buttery smoothProbably just a stuttery mess, as i had it maxed out, with 4x Super on as well, the framerate must have been pretty low
Even if this one doesn't have UW support, if i can run it in 4k, fullscreen, no black bars like 7, it'll be fine
Not long to go now, only about a couple of weeks![]()
There are rumours that they have already started working on Resident Evil 3 Remake. I hope the rumours are true and we can get that in the next 18-24 months. I am guessing it would be built on the same engine with similar assets etc so hopefully it would come out in 2 years or less![]()
Am hoping for a Resi 1 remake also using this engine.
Im getting between 70/80fps at 4k in Resi 7, pretty much maxed settings.![]()
with the 3rd person behind the shoulder view ? could be interesting, i love the job they done on the remaster with the fixed camera angles
Change the rendering method from : Normal to Inverted and you will double your frames @4k and probably not even notice the difference in graphics lol
Inverted made the graphics horrible for me, like a smear over the screen.
Under £30 on PCCan't wait for this, but £40 on PS4 for a remake? I suppose it really has been made from the ground up.
I may use Shopto as others have suggested!
I will probably have nightmares like I did when I was 10 years old.
