I have to suspect these will be binned such that the 3800x won’t reliably hit the same figures overclocked as the 3850X does at stock.
While the 3850X is available anyway... Apparently the process is pretty good and these CPUs are fairly small
With one of them bad boys i won't have to upgrade for a long time for sure!While the 3850X is available anyway... Apparently the process is pretty good and these CPUs are fairly small
10%+ is rumoured, plus the ~20% clock bump and the 100% core bump =My 1700 will be fine for a long time, but if there is a heavy increase in IPC on these chips, i may be tempted. . .
Reported clocks base is +5%, boost +9%. +100% cores and +~20% TDP![]()
Buy a 3700 and underclock.
10%+ is rumoured, plus the ~20% clock bump and the 100% core bump =![]()
No hard feelings mate, but where's the source for this info? This chart is also missing the 2nd Ryzen 9 3850X that was on the alleged 'leak' from AdoredTV.
I will be sceptical on all these leaks until we get something official from AMD themselves. I'm especially having a hard time believing that high-core count Zen 2's can turbo up to 5.0Ghz when the lower core count models can't. Just look at the 2000 series, even the 2300x manages to turbo to 4.2Ghz, just 100Mhz away from the 4.3Ghz of the 2700x.
However, in the event that the table is the real deal, those are some nice specs. The clockspeeds are still throwing me off though, as to which ones are best for gaming (since obviously the Ryzen 9 will be best for productivity).
all i know is the 3700x looks tasty...and if it lives up to its rumours, that'll be the replacement for my 3770k
#fingerscrossed
3600X for me, 8 cores @ 4.8ghz at, I don't know, £250? doesn't seem right to Me though.
When the original Ryzen came out similar things were being said about the 6 core and 8 core parts and their leaked costs. They actually turned out to be pretty accurate.
We are just used to being drip fed the most basic of upgrades from Intel for the last 8 years or so and while I am not 100% sure myself that these prices and specs are accurate, I see no reason they couldn't be.
