Permabanned
- 23 Apr 2014
- Hertfordshire
Got it installed but I really CBA messing anymore. Running 3333 ram still.Anyone had any success with the latest bios, 6401?
Thoughts on the ch7?
Thanks. I got a 2700x recently with a gigabyte b450 micro atx board to fit in my Corsair 350d however I got an evolv x for Christmas and was thinking of getting the CH7 - is it worth it?Great board IMO. More of an evolution on C6H.
ASUS T-Topology is out and daisy chain topology is in. As AMD don't allow mobo vendors to tune IMC FW to board design and AMD guideline is daisy chain this maybe better. Regardless of topology Ryzen IMC is weaker for >16GB in my experience.
Probeit voltage points are more accurate and also software monitoring has greater accuracy. 1 extra fan header on PCB vs C6H plus a connector which allows ASUS Fan Extension card (not included) that allows 3x more fan/temp headers (integrates to UEFI).
VRM has been improved for components and phase organisation. It has 60A mosfets vs 40A, the 10 VCORE phases vs 8, as it's still 12 phases total the SOC was knocked to 2 instead of 4. As board has no display output and a CPU with IGP isn't gonna be used I reckon 2 phases on SOC with increased A is all good TBH. I went from closed case with decent airflow to open air chassis, VRM gets little to no fan airflow, I see around max 50C on VRM when load rig with P95 on OC'd 2700X; this is stonking VRM IMO. The IR3555M also have integrated temp sensor, so on this board it's actual mosfet internal temp and not a diode close to VRM.
Up until AGESA 1.0.0.6 UEFI C6H had Precision Boost Overdrive menu in AMD CBS, now it does not. Only option to get a PBO OC is use Performance Enhancer menu. This change I believe is down to AMD AGESA, as C7H AMD CBS PBO menu was also changed greatly. Before you could tweak the limiters (PPT/TDC/EDC/Scalar VID) now you only have PBO Enabled/Disabled.
Twin M.2, one has support for NVMe and SATA, other only NVMe. If top M.2 is used GPU slots become 8x, TPU has article showing only something like RTX 2080 Ti may see ~3-5% loss in performance on this config IIRC.
There is a modified bios that brings PBO back for the C6H btw.
Fair enough, others seem to have it coming back with his bios so maybe it was a dodgy install? I'm on 1st gen so its largely irrelevant, just thought I'd mention it as a possibility for people.Sold my C6H, thus can't try it. Same author created one for C7H and it does not work. Looking at the portion of UEFI that would be for that menu, author has done something which is not right IMO.
Anyone gong to upgrade CPU to a Ryzen 3x and keep this board? I was going to get a new x570 but the prices will be high so am thinking I will just upgrade to a 3900X if the board can handle it.
Same, initially I though it might be nice to get new board, but decided to check my old CH6 firstAnyone gong to upgrade CPU to a Ryzen 3x and keep this board? I was going to get a new x570 but the prices will be high so am thinking I will just upgrade to a 3900X if the board can handle it.
I have updated the BIOS in preparation, will be interesting to see how it goes. This will be the first time I have upgraded a CPU, normally have to do the board as well.
Looks like the CH6 can handle all the new chips.I posted this in the Zen2 thread, but I may as well post it in here too. P.S It's not my link, from some dude on Reddit.
