Tbf it's circa-$500 less.
This card is a low-volume part, made for the AMD rabid fans only imo and will serve them well![]()
The point I was trying to make is HBM2 is great for 2160p on a card like the Titan V which has the muscle to run at the resolution but this new Radeon card does not fall into that performance bracket.
If anyone wants to use the lame excuse that HBM2 was used to keep heat/power consumption down, seriously this is supposed to be a 7nm card.
The other thing that concerns me is why are the clockspeeds so low for a 7nm card even my crappy Titan RTX with 18.6 billion transistors on 12nm using the standard air cooler can hit much higher clockspeeds.
If the best AMD can do is recycle Vega at 7nm they should have saved their resources and carried on making Vega 56 and 64 cards as these are now very popular and offer great value for money.
AMD really need some new power efficient designs for future GPUs if they want to compete at the very high end, until then they should not waste resources with old compromises.
