Am eyeing up this case, but have a Corsair Hydro 1080ti (Seahawk X).
Can the 120mm rad fit on one of the bottom intakes or stretch to one of the sides out of interest?
Pretty sure it'll stretch to any fan mount.
**update - worked it out. With a little more bravery I just bent/tucked away the USB cables a bit more and the fan goes into place. Nice**
Bought the case yesterday and arrived today. I would like to mount my 360mm xt45 Alphacool radiator on the side vents. I'd prefer to leave it push pull and therefore put one set of fans at the back of the side fan mounts but the top one looks like it will foul the power switch and the USB sockets. Has anyone seen a solution to this? I could just put that 360mm in the roof and my 240mm xt45 on the side at the bottom so the top would leave space due to only 4 fans in total. Thanks![]()
I've got push pull on the side. No issues. H150i.
What layout for watercooling rads with this case?
I'm mocking up my Pc-011 dynamic build and would welcome input on one area. (Both the CPU and the GPU are watercooled and are in one loop on my current pc build.)
I have 2 x 360mm radiators. One is EKWB XE (60mm) and the other is Alphacool nexxxos 45xt (45mm). I propose the 60mm in the roof and the 45mm in the floor. Due to Micro ATX mobo I can fit push pull on the 45mm floor radiator if I want but only one set of fans on the roof radiator and I was just going to set the side 3 x120mm to whatever I finally decide but no radiator.
I was initially going to have the floor rad/fans intake, side fans intake and roof fans exhaust but that means putting some warmer case air over the 60mm roof radiator. The other option is both roof radiator and floor radiator as intake and the side 3x120mm as exhaust. What did you guys go for in the end?
Thx
Manual: http://www.lian-li.com/pc-o11-dynamic/How much space is there in the back for side mounting a 360 rad in the back cavity?
Will a Black Ice Nemesis 360GTX (I think its 54-55mm) fit?
Now you mention it, mine is the same (Razer).Hello all - hoping some of you can help. I've just taken receipt of one of the new Razer variants, and noticed that the side window has pretty heavy tint to it. Just wondering if those of you with the standard case could let me know if this is also present on the original dynamic?
If it is, then thats all fine will just live with it, if not then I'll have to make a decision. Case is great, but as the Razer is effectively the black version, I dont want it to be TOO dark for the lighting I might have.
Thanks for any help
JP
Edit - Image added. Havent taken the protective cover off yet, but doubt its that
https://imgur.com/a/ZFVuyS9
I hadn't noticed until you said though.
I've got the non-Razer, not built the rig yet, I don't recall the window being as tinted as in your pic, will take a look for you tonight.
Can confirm that the standard O11D side window is not tinted as dark as in your picI think I could live with it, but will see. Have you taken the protective film off yours?
Thanks chap - I know it sounds a bit silly, but lets face it we all bought this case for the looks, so making sure its how I think I want it to be is important![]()
is it me or it seems well umm empty, no hdd bays at all?
