What proof do you want? Information was garnered by the press about different attributes of the CPU which allow with some deductive reasoning relatively accurate speculation on the product.as discussed proof that these amd chips are as some state on here. 2 times as fast . faster mid range or low end than 9900ks. people are getting swept away based on a cinebench score. not seen one bit of proof out of 181 pages which shows any of this is true.
We do know that the CPU used was a single CCX 8c 16t die with the I/O die. It's also a 65W part according to the tech press from the event. It's also confirmed that the lower position on the die will be filled with another 8c 16t ccx or lower binned 6c 12t CCX to allow for the 12c 24t version, just as the Ryzen 3 model will likely run a 6c 12t single die.
We also know the range the frequency of the CPU used was which is between 4.0GHz to 4.5GHz. There's quite reliable info that it was actually running at 4.5GHz but it's not 100% confirmed.
Other points are, the CPU ran 57W lower than the 9900K during the test run and we also know that it didn't have a boost clock just an all core clock so it's idle wattage was basically at TDP with 66W.
Extrapolating performance of the 16c product from that run assuming same memory and similar scenario and factoring in further losses at a 10% perf loss puts it at ~3900 for a Cinebench run beating all the 16c processors currently available.
Yes there's some educated guessing and speculation going on, but we won't have hard data for a while and it'll be interesting to see how close those guesses are when we do. The last point DG is you are dogmatically asking for proof of a negative then trying to use that as some justification for trying to **** on everyones discussion. If you have something useful to add, please do so. If you just want to act salty don't bother. I couldn't care less if you want the 3xxx to beat the 9900K or not. Most here trying to discuss the new Ryzen's don't care either.
It's interesting that it beat the 9900K at stock settings with the motherboard auto-OC still active, but to those interested in the Ryzen's it's nothing more than intriguing and finding out that the SKU is basically the leaked 65W 3600 non-X part is even more intriguing.
