Subnautica
Are you farming them? You cut one grown marblemelons into 4 seeds and you then have a endless supply.
I didn't know I could do this until after I'd eaten the whole supply on the floating island :D
Still the lanterns and potatoes kept me going.
Working on my Cyclops now - attempting to migrate to a new base deeper down somewhere with resources. I've kitted it out with titanium and lockers etc, so I can build when I get there. But still trying to find a fragment for the drill arm for my Prawn so I can mine.. Proving a challenge.
Getting a bit bored with the game now I've kind of come to the end of any story threads and don't have any kind of direction to follow, found the lost river but don't have much motivation to explore it. Built a Cyclops and Prawn suit because I could but have little use for them at this point.
Not sure if it is the same as for me but there is a wreck to the far North West that has a lot of Prawn fragments.
You've not finished all the story yet. There must be something that you've not discovered/explored properly. Check your little datapad thing for any unread clues in the "clues" section or whatever it is called.
I've got a general feel for the story - played enough games to pretty much figure it out from what I do know but seems to have completely trailed off in terms of threads to follow to the next bit.
There're two things I can think of -
1) You've not progressed enough (in term of in-game days)
2) You have got far enough but not checked all the radio messages out completely
I'm trying not to give too much away but have you had any communications about the Captain of the Aurora?
I've had one about the CTO or CEO or something at lifepod 2 - one of the more recent - I've been there.
Have you gone to all the way points? I think if you still have a waypoint showing for the underwater bases you haven't found all the PDAs at that base.
AFAIK all done - none of the way points show up unless I manually go back and set them to show again.
Have you explored the Aurora yet? What tools have you got so far? Some stuff is only accessible once you've obtained the fragments for and made certain tools. If you've only just got to the Lost River, you're nowhere near close to the end of the game yet. There's still loads to do.
Done everything in the Aurora, have the stasis rifle, etc. and all the upgrades for Seamoth, Cyclops and Prawn suit, also done both islands and probably visited every wreck within 2km of the starting position.
Have you explored the Lost River thoroughly? I've had a quick Google and there's a radio message that will trigger after you've been to a certain place in the Lost River.
I found my object locations to be very different from some players. Took me ages to find the schematic for the compass...
I can't even find the lost river.. Without a map its difficult to know where you are. Beacons obviously help but only to a point. I may have explored some of it, without realising. I have the Stasis gun blueprint now, along with a lot of blueprints for the Cyclops and Prawn etc, but I can't find key ingredients to upgrade them. Things like Nickel Ore, I haven't discovered any yet.
