It's 2 years, ALL Acer monitor warranties are 2 years. I'm unsure what the confusion is here?![]()
It's 2 years, has been in the UK for a long time. If it's changed I'll be v surprised.
Competitor website said:Manufacturer Warranty 1 Year
good thread from some owners with a chart breakdown on the xv's capabilities at 1440p/4k, it seems the monitor needs a firmware update to enable 4K & HDR at upto 120hz at the same time, which currently does not work but is written in the manual that it should
https://www.reddit.com/r/nvidia/com...73k_dual_displayport_support_on_the/?sort=new
HDR and freesync don't work at the same time, would be awesome if that could come with a FW update but not holding my breath.
when setting HDR on the monitor OSD it disables freesync for me, so thats not working. you can send a 10 bit 60Hz signal though without going into the HDR profile so that may offer some benefit. I cant get 86HZ 10 bit either, have set custom res and can apply the refresh rate, but as soon as i select 10bit RGB and hit apply it tries and then falls back to 8 bit.
happy with 120 8bit thoough, will try shadow of the tome raider later and see how the GPU holds up for that.
Is that with a single hdmi cable?
