I personally don't see that causing anything other than chaos. I can't see them doing that.So many removed posts :O
Reckon the Ryzen lineup will launch at different times? eg 6/8 core first, then 12 and 16 a month or two later?
16 core version might come later, holding up 12 cores would be equal to AMD shooting itself on foot with shotgun.Reckon the Ryzen lineup will launch at different times? eg 6/8 core first, then 12 and 16 a month or two later?
I hope TR2 is released soon after Ryzen 2. I'm hoping for 32 cores without having to upgrade from a first gen x399 motherboard so I don't have to go E-ATX or get more powerful VRMs + cooling on the mobo.
I personally hope that TR2 will be 8 channel memory (like Epyc) so actually hoping we'll see X499 motherboards and not have to have memory channels crossing cores etc!
As long as there's an ATX option!I personally hope that TR2 will be 8 channel memory (like Epyc) so actually hoping we'll see X499 motherboards and not have to have memory channels crossing cores etc!
I guess that rules out X399 boards by default then as they are only 4 channel without the required traces for 8?You do forget that TR2 CPUs will be with the same I/O die providing ram access to all cores.![]()
Sorry that's how I read your post - apologies if I've misunderstoodAnd who said that the TR3 will have more than 4 channels ram?
Sorry that's how I read your post - apologies if I've misunderstood![]()
New TR3 going to be some pretty beasty CPUs.But if they could release them in May then why would they wait an extra month?It won't be a May Launch, it'll be June after Computex. As I suggested above, we'll likely see announcements in May given it's the 50th anniversary, but nowt will hit the shelves until June.
