- 26 Sep 2017
- In the Masonic Temple
Okay, I just did a system restore to the 6th of february when everything was perfect.I can confirm all of these issues.
I first thought the crashes was a result of the underclock, so I left wattman at stock and still received them.
I thought it was due to Freesync so I disabled them, and then I noticed windows had the tears you mentioned.
I then changed my hz from 144 to 120 to see if it was a display port issue, but still had the crashes.
I've changed the Display port cable to two different ones (all three I've confirmed worked before) with crashes.
I really feel like this is a driver issue that's specific to certain hardware.
At this point my thoughts are a faulty card, faulty driver, or not powerful enough PSU.
I never owned Vega 64 or 56, but my understanding is that the Liquid version of it required a minimum 750-1000w psu, but again that's at stock and those cards (as well as this one) undervolts very well. If these cards cause power spikes that aren't easy to measure, it could be the cause of this instability, but I feel like any number of reviewers worth their salt would have caught this.
I installed the latest chipset drivers for my MOBO just in case. (at this point everything worked properly)
i installed the radeon 7 drivers and the problems have instantly come back, I have the weird lines of random distortion on the screen (like lines of static briefly appearing)
This is before I have literally even opened the newly installed crimson GUI
Is this the card or the drivers, I REALLY REALLY need to know
with 20% Powerlimit.
