Don
- 20 Oct 2002
- Oxfordshire / Bucks
It's the same
Thanks![]()
Have they fixed wattman ignoring the zero rpm fan setting yet?
Btw guys if you have issues with Zero RPM not working, just go to Global Wattman, hit 'reset' then 'apply'.. then load your profile again for Zero RPM to kick in![]()
Which GPU Tony?Meh.
After the issues I was having with the 19.2.1 driver regarding my core and memory dropping to the floor every 5 or so seconds, I decided to try the new 19.2.2. Exactly the same again, every 3d application my core and memory just tanks, the lights on the GPU drop right the way to show only 1 lit then it bounces back up to all lit again. I've just updated my chipset drivers, flashed my motherboard bios to latest but still the same issue. Now going back to any driver pre 19.2.x everything is absolutely fine. What the hell can the issue be guys? @LtMatt please any idea, it's driving me insane this one. I want to update the driver for the newer titles but can't install these latest due to the issues I'm getting.
Which GPU Tony?
Am using Radeon VII and Vega 64 on 19.2.2 and don't see those issues.
@TonyTurbo78
This is what I was getting that time when you was helping me find good clock speeds.
Clocks tanking only happens to me when i enable Chill.. thats why i never use it.. i just want them to stay at the overclock i put them at but seems like Vega wont do that on the core but memory is ok if i set State 3 as Minimum State. Have you tried setting Minimum States @TonyTurbo78 ?
Yeah its weird, trouble is, it's nothing to do with clock speeds Shanks mate. Even using Power Saver/ balanced/Turbo or even custom, results in the same issue. Why all of a sudden is it only doing it on the 19.2.1/19.2.2 driver though? Was fine on every driver before these. I rolled back again to 19.1.2 and it's absolutely fine, flying along at 1750/1100 with no stutter or clock drops anywhere.
Never once used ichill Brains. I've tried lots of different clocks speeds and states mate, it does it regardless of my wattman settings. How do I got about setting state3 as minimum just to test it? I take it you just mean clicking state 3 in Wattman so it gives you the option of setting as minimum state?
Very strange indeed. Am afraid I can't help you here has I don't over clock my GPU that far.
