Caporegime
- 29 Aug 2007
- Auckland
None of this will work to actually keep your hair. Minoxidil basically makes all your follicles grow at the same time which gives the appearance of a fuller head of hair, but its just a lie; it will fall out.
Shampoo and conditioner are bunk.
You have one option: Finasteride. Get on it, or accept your hair doom.
Nah she's not into comb oversYou do realise that's code for your wife fancies me?
And do consider that if you are really thinning, and you chop it all off, it'll probably never come back.
Just been reading some Norwood Reaper threads on bodybuilding websites. Pretty amusing.
Is that true? Shaving hair has no bearing on the resilience of the follicles!
do they really with scientific evidence to back them up? my partner got me some elvive fiborology thickening shampoo/conditioner and I tried them for a few months, don't notice any difference.Are you already using/tried thickening conditioners or similar? some work to a degree for some people.
Not that I'm going bald just my hairs are really thin
But it's already growing slowly and thin, so forcing it to start from scratch will mean it probably never recovers.
That's not how hair works.![]()
When I started going bald I went straight from waist length hair to a few mm. 2 on the standard shaving grades. Well, actually I initially went to a rough shave because the first time I used the shaver thing I forgot to put the relevant guard on and shaved a strip to 0 grade, i.e. a rough shave, so I had to do the rest to match![]()
Yep. Looks good, much better after.Agreed (actual homo).
