Don
- 20 Oct 2002
- In a house
Took it for an MOT which it failed
Took it for an MOT which it failed![]()
Oh dear, what did you miss?![]()
Rear caliper binding slightly.
Only issue, apart from an advisory on the rear tyre, annoyingly.
Caliper rebuild kit is here, along with blue fairing bolts and brake pads
Also, got a little 500kg bike lift turned up today, so will get that sorted over the weekend!
The fairing bolts aren't those crap anodized ones are they? Woeful things. Broke so many off it's unreal.
Yup, blue anodized type. All went in ok so far!
I stripped and rebuilt the caliper with new seals, emptied, refilled and bled the system and it passed, just an advisory on the rear tyre.
I will sort that out asap.
Been on a bit of a ride out today and really feeling more at home on a bike and getting used to it.
Bike is hitting 70 on the flat happily and can just about hit 75 if I wring it's neck and get behind the screen.
I also made some front wheel downlights as DRL from LED strip, and hooked it up to run with the sidelight bulb.
I am not happy with the headlight bulbs. The LED is not doing enough sadly, so will swap the dipped bulb to a halogen.
I may go get some of the higher power bulbs if they do not throw enough light.
I must say I thought of you when looking at bikes. I’ve seen your success with the Chinese marques and I considered getting one of those instead for a significant discount. However, thats a 2008 bike, 11 years old and it still looks near showroom condition. I convinced the wife on the basis of an investment - it’ll do for the grandkids tooSmall Honda. Cant beat them![]()
I must say I thought of you when looking at bikes. I’ve seen your success with the Chinese marques and I considered getting one of those instead for a significant discount. However, thats a 2008 bike, 11 years old and it still looks near showroom condition. I convinced the wife on the basis of an investment - it’ll do for the grandkids too![]()
