Obviously, not going to go through 200+ pages to see if anybody has ever done this before.
However, I have an old E36 compact 1.9 16V (140). The original tyre spec was 225/55R16.
The tyres that were on her when I bought her (For only £300) were Chinese crap. I have always hated them but since they still had tread I was also always a bit Yorkshireman too and wanted to wear them down a bit before replacing them and since I am not a hoon any more I thought I could get away with it.
Anyway, last week I just got too fed up really. (Fishtailing on a dry road by using kickdown at 25, really!
They were also horrible and noisy and tended to "Follow the road" so irregular road surfaces meant a constant struggle.
Aaaanyway,
My Tyre Guy (Who I have known for decades) basically suggested that not only should I go for Goodyear "Winter" tyres since I only do a very low annual mileage (So summer wear isnt a problem and the performance would be excellent all year round) but that I should also go to 205/55's on the grounds that the original spec are actually too wide for the wheel/chassis.
And he was spot on.
Car is transformed out of all recognition.
Really!
I dont know if this is the case across the E36 board. And I also dont know how much of this is simply that I now have a decent set of tyres and/or the reduced dimensions of said tyres.
But I would say that anybody with an E36 compact with the 16" sports wheels
really should consider this.
HTH
