- 24 Sep 2005
- Middlesbrough
So I was fortunate enough to be given this for a weekend. Massive thanks to Tesla Leeds.
Thoughts:
If I had the money to buy one of these £100,000-£140,000 I was told, I'd get something else. If I lived in Central London then yes I can see the appeal but I do a lot of motorway miles so I just couldn't cope. Superchargers were just too far apart from each other and the nearest one to my house was 30 minutes away (Scotch Corner).
Hopefully battery tech will improve and the range improves
Thoughts:
- It's absolutely rapid. 0-60 in 2.9 seconds. Sat at any speed, you tap the throttle and pretty much immediately you're at licence losing speeds.
- The quality is to a high standard (for me anyway). Seats we're comfortable, decent sound system and full of the latest tech.
- Fairly quiet in the cabin. All you can hear is a turbine type noise when accelerating, a bit of wind and tyre noise and then the cooling fans for the batteries after pressing on which are quite loud
- It's completely soulless. Reminds me of the latest Apple products and just couldn't really connect with it.
- Battery apparently lasts 300 miles but I was lucky to get about 200 from an 80% charge. I charged it up 5 times over 3 days to 80ish%
