- 5 Sep 2011
- Surrey
wow your chip requires a ton of vcore to run 5ghz or is your vcore that high to get those mem clocks?
The VID is quite high anyway but some CPU need that much. Under AVX load, with differential sensing on the Formula the voltage is around 1.315v. That's without an AVX offset. It's always better on the CPU and temps to run a higher VID with lower LLC.
