How did you find doing the 14mm top mount bolts? I used some drop spanners but access was tight and you can only tighten to what you think is right. Did both my fronts except the springs 2 years ago (can't think why I left the springs now seeing as I did the lot) and still on there good though.
Once i had the springs tight down, i just used my impact gun to give it a once over, then took the spings off. Worked fine!
