Man of Honour
- 21 Nov 2004
Pathetic deadlift session this afternoon. At least I had a strong chest session yesterday. Will drop the weights and build back up. Legs and chest going well at least.
It felt a lot better this week.
When you say take the belt off... I wear it because I have a problem with my lower back (I've got an MRI on it tomorrow) so I want to do everything possible to help prevent further injury. At what point should I start wearing a belt? I'm 70kg and currently going for 3x8 at 90kg.
You have an undiagnosed back problem... and you're squatting?
Whilst I commend your enthusiasm (and I have done similar), I would strongly suggest rethinking your training program!
Squatting WITH a belt is not protective in this instance and - if you do compromise your form - will potentially lead to a bigger blowout. Get rid of it.
I really need to get over it and record my squats, maybe I can figure out why this hip pain won't go away.
That's interesting. I do a pretty long warm up starting with the bar as recommended by stronglifts but that does look good for mobility.
How long did most people who started with stronglifts stick with it before moving on to other programmes? I have now had to deload 10 percent and work back up on pretty much everything as had 3 failures at a given weight. I don't mind that and think my form is improving for it. I feel I can still make progress with it but not sure when and what I should be moving on to. Any thoughts?
I still follow this https://forums.overclockers.co.uk/posts/29878006/ - still gain, occasionally hold the weight for another cycle or drop down and build back up. I typically add 2.5kg to the max lift after each cycle. It is tough, but it works. The only part I don't follow are for chest and I have also cut out front squats and now only squat once a week - twice a week was destroying my hip flexors.
Thanks, looks interesting. What should I take as a signal to move on from stonglifts? My squat and deadlift are ranked intermediate for my age and weight but my bench is still low (80kg) and I OHP like my 8 year old daughter.
Do any kind of pre-squat warmups? I still do this before I head off to gym for my squat/deadlift session: Kelly Starret - Squat hip opener I do do something else, but cant remember where I saw it, basically to get my hips activated before I squat.
Squatting WITH a belt is not protective in this instance and - if you do compromise your form - will potentially lead to a bigger blowout. Get rid of it.![]()
For pure progress reasons (rather than enjoyment or doing a program more aligned with your goals), the main signal would be - if you're going in circles stalling, back-cycling and working back up to the same point over and over. This obviously works for a while with linear progression but isn't a long-term solution: at some point you have to do what all intermediate-onward programs do, which is
1) employ some form of periodisation. For intermediates this doesn't have to be super complicated, but the program should take into account progress will tend to be at best weekly, rather than session to session. Madcow and the Texas Method are the next progression from Starting Strength for instance, but there are obviously lots of more powerlifting-specific templates out there or smart bodybuilding ones that are based around big compounds (like the ones from The Muscle & Strength Pyramid books you can find online).
2) increase training volume (and work capacity in order to be able to handle more volume); a lot of beginner programs are low volume as that's all that's needed (no point doing more when you could get the same results with less work) but eventually you have to start putting more work in to keep progress going. This is tangled with point 1, since more work = more fatigue and why on an intermediate program you might work with %'s of your max or within an RPE range rather than grinding away like you tend to do when things start getting hard on the beginner programs.
Hi all I've been doing stronglifts for a while now my squat is progressing finally! Although 3 times a week my legs are still struggling to recover before the next session.
Wondered if it's worth upgrading my squat rack which is currently a bodymax cf415 and buying a power rack? Something like this https://www.mirafit.co.uk/mirafit-250kg-power-rack-with-cable-system.html
Today's squat and deadlift session was interesting, bought that EatLean cheese from Tesco on sale and ended up eating half of the 350g pack. I started to get very gassy just before the workout and bad to go to the toilets a few times to "let some steam out"![]()
