Can't remember having one on my S7+ it's not just plastic protective stiff you peel off is it?
S7 and S7+ do yes. Good screen protector too.
@Gman, sounds like you have a row of dead sub pixels. New screen required if thats the case.
Oleds do have tint issues off axis but in my experience that varies greatly between generations. My note 4 went really green off axis. S8, not so much. I guess it depends on your usage as to whether its acceptable or not but by the sounds of it if you are already on your 2nd device then I dont know if you'll find an acceptable one.
unnamed by agentwalker12, on FlickrGrrr I knew I saw this today when randomly in the app. Come home and thinking about ordering a charger and it's gone now. Not paying £60 for a wireless charger.
Theres a second wave of stock due next week Nit sure why its saying 29th?Just my bl**dy luck, I changed my S10 pre-order to a S10+ on the 5th and right up until today it has been saying my expected delivery date is the 15th. Now it has just changed to the 29th, another 2 week wait.![]()
Hmm , do I take the protector off or not?
Finger print sensor is much improved with it off.Hmm , do I take the protector off or not?
Just below the sensor, about half a centimeter from the edge.Is that smack bang in the middle of the screen horizontally? Is it near the fingerprint sensor?
