glad it works at stock and all sorted, but yeah, unfortunately it appears your card is a bit of a dud for overclocking![]()
Thank you. At lest HBM OC`ed good enough... I think OC`ed HBM gave me a very good boost in perfm...
Can you tell me from GPUZ who makes the HBM memory on your card. I know hynix RAM does not overclock at all very well and 930 is just too much.
Ahhh thought so. You need to lower your HBM overclock. The guys with HBM on the vega 56 forum have hit a brick wall trying to overclock Hynix. I would lower it and test in increaments until you find a safe overclock.Hynix HBM, here is screenshot of GPUZ: https://clip2net.com/s/3ZShxGT
Sorry to hijack slightly but what would the minimum power supply you could get away with? Looking at the Vega 56 myself and have a 620w PSU, 4670k @ 4ghz .
Thank you, I`ve already found stable OC: 1500MHz on core and 930MHz on HBM
don't oc the card?I thought I found stable OC but nope...
don't oc the card?
seems like you lost the #siliconlottery
Does the issue occur straight away or after a while. I only ask as I have been having major performance issues with my vega pulse which turned out to be avast and also bf5 filling free memory. Turning off avast whilst gaming and running ddu memory cleaner has made a huge difference and I can now game without stutter. This always occured 30 mins into gaming. If not ignore me![]()
Is this normal for Heaven Benchmark 4.0: https://clip2net.com/s/40sm3E6, drops on core clock and power draw?
Also, try running Unigine Superposition 1080p Extreme Benchmark. I just tried it to see if the power draw didn't have a few extreme dips like Heaven or Valley, and indeed it didn't:
Green line beginning of bench, red line end.
Usually benchmarks works fine. I`ve run Unigine Superposition 1080p Extreme on Balanced and OC`d, everything is stable: https://clip2net.com/s/40sRN4m
Also, I tested my GPU on my brothers PC in Rise of the Tomb Raider and everything is stable even OC`d to 1592MHz at 1000Mv (actual 1503MHz) and HBM 935MHz at 1000Mv... now drops on core clock and HBM...
Now I think, it could be New Power Supply, Drivers or damaged PCI slot on my Motherboard?
Any ideas on how to and what to test?
Thank you in advance!
Make sure you are using two separate PSU PCIe power cables, not just two connectors on the same cable.
Unseat the RAM sticks and seat them back in firmly. Set the RAM to stock speed. Run Memtest HCI. Set RAM back to 3200. Run Memtest HCI.
Try Windows 10 High Performance power plan.
Try with Game Mode on and off.
