- 11 Jan 2008
- North Yorkshire
I'm generally happy with mine, but there's a few shaky quality areas here and there. I think the Razer tie in and the addressable RGB strips with controller have eaten a chunk of the budget.
Undoing the thumbscrews on the top panel for the first time revealed they were both actually crossthreaded, so its a mess of swarf up there. Good job it only holds the top panel from sliding. The other gripe I have is the back of the case. Why dust filters on the top, bottom and sides, then a gaping hole above the PCI bays and non filtered slots where almost all cases have a rear exit?
Once its all together it looks great though. Thanks to OCUK for agreeing to swap the mopuse for a strimer cable, great customer service.
Undoing the thumbscrews on the top panel for the first time revealed they were both actually crossthreaded, so its a mess of swarf up there. Good job it only holds the top panel from sliding. The other gripe I have is the back of the case. Why dust filters on the top, bottom and sides, then a gaping hole above the PCI bays and non filtered slots where almost all cases have a rear exit?Once its all together it looks great though. Thanks to OCUK for agreeing to swap the mopuse for a strimer cable, great customer service.
