Dirt Rally 2.0
yes I tried most of the tweaks I saw online ,but it just feels like the FFB isn't giving you much info on what the car is doing or the bumps,oh well lets hope its patched soon
Dirt Rally 2.0 PC Settings there are quite a few you can turn down to increase your FPS-
The settings marked with ** are double figures which have the greatest effect on FPS so turning these down should improve your gaming.
The different settings that you can tweak in Dirt Rally 2.0 PC are as follows:
Multisampling
Multisampling is the single most taxing setting and can impact performance by up to 39% depending on the hardware that you are using. You should turn this down if you want better performance in Dirt Rally 2.0.
Anisotropic Filtering
Anisotropic Filtering also makes a small difference and can impact performance by up to 4%.
TAA
TAA also has a significant impact on the performance of the game. You can get 12% better performance by turning this setting down.
Shader Detail
Shader detail only has a minor impact on performance and you can leave it as is.
Reflections
Reflections can significantly impact performance and you will notice an improvement of 10% when you turn this setting down.**
Screen Space Reflections
Screen Space Reflections can also be taxing on your hardware and can impact performance by 11%. You should turn this setting down if your hardware is not able to keep up.**
Shadows
Shadows can impact performance by 7%. This setting is not as taxing as others that we have mentioned but you can turn this setting down if you are unable to get to 60 FPS.
Night Lighting
Night lighting has a minor performance impact of 2%.
Ambient Occlusion
Ambient Occlusion is taxing on hardware as always and can affect performance by 12%. You should turn this setting down.**
Advanced Ambient Occlusion
Advanced Ambient Occlusion is not as taxing on the hardware as Ambient Occlusion and can impact performance by 5%.
Particles
Particles also hit the graphics card and can impact performance by up to 7%.
Advanced Blending
Advanced Blending is not all that taxing on the hardware and can impact performance by 3%.
Weather
Weather can impact the performance of the game by up to 6%.
Crowd
Crowd setting also impacts performance slightly and you will notice a boost of 3% if you turn this setting down.
Mirrors
Mirrors can impact performance slightly by 1%. You can leave this setting as it is.
Vehicle Details
Turning down this setting can impact performance by up to 3%.
Object
Object impact performance slightly but turning this setting down will give you a boost of 2%.
Trees
Trees impact performance by less than 1%, so you can leave it at the default preset.
Ground Cover
Ground cover has a major impact in performance and you can get up to 22% better performance by turning this setting down. This should be one of the settings that you tweak first.**
Skidmarks
Skidmarks can impact performance by 5%.
Motion Blur
Motion blur is very taxing and can impact performance by 12%. You can turn this setting down in order to get a major boost in performance.**
Bloom
Bloom has a slight impact on performance when playing Dirt Rally 2.0. Turn this setting down in order to get 2% better performance.
Lens Flares
Lens flares also have a small impact on performance of less than 1%.
damn,i played 5 mins of it and not touched it since,just feels so bland with the way FFB is now :(
I did the XML tweak for FFB just as a matter of precaution and been having great fun playing DR2.0
No problem setting up my wheel with a few tweaks while playing its been great why miss out?
DiRT Rally 2.0 - v1.2
DiRT Rally 2.0 - christina.mcgrath
Hi all,
Today, v1.2 releases at 11am – at which point, RaceNet will go down for maintenance – so please make sure you’re not playing the game when 11am comes around as it could compromise your event times uploading to the server. We’re expecting to be back up and running by 12pm, so don’t worry – it’ll be a maximum of an hour’s down time before you can get back to being DiRTy!
For those of you keen to know what today’s update will bring, the full list of notes is below:
• Stability improvements across all modes
• Prevented negative times from posting to leaderboards
• OSD Dial can now be enabled in headcam
• New engine audio for Citroen C3 R5 and Ford Mustang GT4
• ‘Upgraded’ trophy/achievement will now unlock
• Darkness issue resolved when using interior cameras
• Softlock will no longer occur if user owns too many vehicles
• Proximity indicators are now available for rallycross
• Prevented exploit for claiming rewards multiple times
• Podium counter will now correctly update in My Team
• Prevented audio cut outs
• Joker Lap cut-scene is now skippable
• Custom online will no longer disconnect users in specific conditions
• Improvements and corrections to text (all languages)
• Improvements to subtitle content
• Accented characters will be entered correctly in user text fields
+ Server-side change: we’ve also tuned frequency of night stages and bad weather stages. We know a lot of you were reporting that the occurrence of dark/wet stages was a little too frequent, so we’ve done some tweaking to ensure a few more dry and day stages
Thanks,
Team DiRT
Nice to see something moving. Still having fun in the game despite only 6 unique stages in reality (meh). And I still think the cars behave more naturally than in DR1 even though some Polish wheel elitists say otherwise. I'm just a pad peasant but I don't think the cars behaving like huge soapboxes equals more realism.
Can't comment on FFB, obviously.
I got up from night shift at 12 to turn it in incase I had bad WiFi but luckily there’s fibre optic so only took 10mins:D so been on all afternoon. Suffered my first fatal accident in New England just after a drone came in low over my head then over a jump and into a fence. Also found out what happens when you don’t pick the right tyres for the job, had normal tyres on for the first round then never changed them to wets so had to slide round Spain to victory(just) to take the championship! finished all 6 locations and now wandering what to buy next to go through it all again:D
can see this being my most played game in steam. Catching up on GTA5 hours already
What’s the launch control in the settings? And has anyone used it? Be more for the steering wheel drivers would it?
Launch Control essentially a secondary rev-limiter for the engine that is activated when the driver holds down a momentary switch on the handbrake.
Its in game settings give it ago, some of use drive with launch control off, assists off or any other setting that gives you the edge when using a wheel Dg for one.
probably monaco which releases tomorrow. :D
bagged a world record just now in the peugeot 205 gti in argentina whoever set it was quick took a few hrs to beat it.
