I thought Ajax didn't play football??
But due to their history and achievements, much better side than Tottenham, anyways, who won't have key players for the next game too.
If the Barca of the first leg or first 20 minutes of the 2nd leg show up then we'll terrorise them. We're perfectly set up to play vs Barca but any side with Messi in has always got a massive chance too. One thing's for certain, it'll be an entertaining tie.I dont think Barcelona are all that they showed in first leg vs Utd there holes they allowed Man Utd to play and if they do that vs Liverpool they will be destroyed imo.
And they have no quality players either.
So they don't deserve to win anything.
Err, Tottenham is worse, got through by pure luck.
HandballIf it hits his arm (which is tight to his body) and then diverts into the goal off his hip, is it a goal or and handball?
Does that mean that Nottingham Forest are also better than Spurs?But due to their history and achievements, much better side than Tottenham, anyways, who won't have key players for the next game too.
I don't think he is commenting that it is a handball,just that it hit his arm, which it didI think Rio's had too much coke.
That's what I thought the rule was. The ball hit his arm (which was tight to his body) but didn't deviate in direction until it rebounded off his hipIt's definitely hit his arm but it's not a handball. His arm is tucked into his body and it's not a deliberate movement or anything.
I really don't know why I'm arguing with you!
That’s why it needs to be totally black and white. Forget all this deliberate stuff. If a handball stops or leads to a goal it’s a handball, end of. Too many grey areas with the deliberate stuff.Wouldn't matter if the ball did deviate or whether the ball directly went in off his arm. It's only handball if it's deliberate which that wasn't under any interpretation of the rule. He's not moved his arm to the ball nor has he put his arm in an unnatural position to gain an advantage.
