Most of what you said here is wrong AND your own links prove it.
Click your Samsung and global forge strat colab link, it straight up says this
I had a suspicion someone would point that out but i honestly couldn't be bothered to go back further in time when this sort of stuff is publicly available in the first place and mentioning what I'm about doesn't change the original point that 12nm was not a mature phone/tablet CPU node. If you want to get further into the origins of the non-Intel 14nm node then try using Google, I'll even start you off with this article that tell you how...
Now how much of the 14 and 12nm that was eventually used in Ryzen came from each company in that common platform agreement, the strategic collaboration, the buying up of IBM's plant, process, and numerous semiconductor technology IPs is, i would say, subjective as that information is not publicly available for obvious reasons, we can only speculate.Ever since GlobalFoundries was spun off from AMD in 2009, Samsung, IBM, and GF have maintained what they called the “Common Platform.” Common Platform was an agreement on broad technology standards that would be deployed across all three companies. It was never entirely clear which technologies were governed by CP rules and which were independently developed, but the goal was to create an infrastructure that allowed for easy design porting across all three corporations.
Full stop, that's the end of it. Anyone not bs'ing their way through basic knowledge knows that IBMs 14nm was decent but had very different design parameters, it was designed primarily for IBM chips, that is screw power efficiency, max clock speeds were the only concern, it was more expensive and was focused on producing a relatively low number of extremely high cost server chips. It was basically unsuitable for creating more efficient higher yield cheaper chips. So straight off, and this was incredibly widely and publicly known, Global dumped IBM 14nm and licenced what was a fully Samsung process node. The original Zen was made on a purely Samsung node, developed by Samsung for mobile with the focus on efficiency and being high yielding and it went into production before Global did and it was licenced by Global. Suggesting this was originally an IBM node literally immediately highlights that you don't know what you're talking about here. Here's a hint, if one company licences a node to another company... they won't launch it before the company who actually finished it then licenced it.
Firstly I'm not bs'ing my way through with basic knowledge, secondly I'd appreciate if you could keep the ad homeni attacks to yourself.
Thirdly I'm fully aware of the characteristics of IBM's 14nm process but diverging into a long explanation as you've done above is completely irrelevant to the history of where the 14 and 12nm that's used in Zen and Zen+ came from, it was suffice to say IMO that IBM had the first working 14nm FinFet outside of Intel way back in 2014.
If however you want to get into a discussion on how much of that FinFet on a SOI substrate ended up in Zen and Zen+ I'm more than happy to have that discussion but perhaps a thread about Zen2 isn't the place to have it so feel free to start another thread.
Secondly, the defining characteristics on size and electrical performance come from in huge part the basic parameters of a node, the basic gate pitch, metal pitch, they pretty much define the 14nm Samsung node as what it is, 12nm makes no significant changes and ignoring the headlining numbers, 12nm is 'faster' not because it's denser, but because slightly thinner taller gates allow the chip to be less dense.
Keep in mind that Intel relaxed transistor gate pitch for subsequent 14nm nodes, that's how the clock speeds went up. 14nm had a transistor gate pitch of 70nm, 14nm + didn't officially raise it but supposedly did in the design rules, 14nm++ is a transistor gate pitch of 84nm.
Intel called all their node tweaks 14nm/+/++/+++, in the past they would have called them a new stepping on a shipping chip. With ostensibly the same cpu they wanted to make the changes sound bigger than just a stepping. With Global they wanted it to sound like a bigger improvement and they gave it a new name. It used the same equipment, it used the same patterning, it has the same physical limits, it just tweaked the design, nothing more or less. On any given set of equipment and choice of patterning you are really limited to certain physical size parameters, within those limits anyone can choose to optimise for density, voltage, performance, in fact many or most nodes do that upfront and have different designs on purpose, 14nm industry nodes were really the first where they only really bothered with one design largely because Samsung planned to go 10nm before 7nm and earlier so wasting time on extra versions of 14nm apparently didn't seem worth it to them.
https://en.wikichip.org/wiki/14_nm_lithography_process
Look at Intel, they started off, before launch, with an optimised high performance, low voltage and high density library. 12nm is nothing more than a tweaked 14nm with different design goals, using the same equipment, using the same physical limitations, using the same patterning. No one in the industry would call it a new node.
Also note the IBM 14nm, it is dramatically larger despite being 14nm, because lower density = higher performance in general. This is why Intel's nodes decreased density to raise clock speeds, IBMs node was completely unsuitable for a high volume, high yield, lower cost chip and still is, also a really really big deal here, IBMs 14nm is SOI, Samsung's is bulk, no Zen chip is produced on SOI, full stop.
https://www.globalfoundries.com/sites/default/files/product-briefs/pb-14lpp.pdf
You will notice here, particularly top of the second page, twin well CMOS bulk FinFET, with every single design parameter matching Samsung 14nm and nothing matching IBMs 14nm SOI node.
Jesus H, and you accused me of bs'ing my way through with basic knowledge, that's not even worth a response.
Although the "defining characteristics" part did give me a good laugh.
And what's with the rant about Intel got to do with anything?
My 3570 is really showing it’s age and the Vega 56 I got from OCK has been awesome.
