So your 6700 is designed to pull roughly 80 Amps through when under full load, not overclocked.
Amps * Volts = Power
80 Amps * 1.25 Volts = 100 Watts
So under a full all core torture test your CPU is going to draw way more than it's listed 65W Power. That is why looking at the VRM's on a board is important as it is those that supply all the Amps.
The 80 Amps is purely a guess by the way, I have no way of knowing the power draw of your board... but it is going to be around that number.
It is one of the things that may see me upgrade my board for Zen 2. I am on a Gigabyte B350 board with a 4+3 VRM... I don't really know what power output I can safely draw from it, I do know that it was tested with a Ryzen 7 at 4ghz drawing 236w of power, but I don't think that is a really sustainable load. As long as the Bios can be updated to support it I should be good to run at a minimum an 8 Core Zen2 with it's more power efficient design.
