Z390 Aorus Owners thread
1 Dec 2015
Mmm Aorus new cooler ...
https://www.anandtech.com/show/14222/gigabyte-to-launch-aorus-atc800-cpu-cooler-a-beefy-tower
Used the last one, best ever mounting system that you'd need a PhD to appreciate and mount it !
https://www.google.com/url?sa=t&sou...AxAB&usg=AOvVaw0DVzeAdSRuZTlodMp9zqQ9&ampcf=1
Looks like this one should be simple as it's cooler masters MA610P
http://www.coolermaster.com/cooling/cpu-air-cooler/masterair-ma610p/
22 Aug 2009
3 Oct 2007
London, UK
Am I missing a setting here guys? I have G-Skill 3600CL16 which is Samsung b-die. If I try to tighten the timings from the XMP which is 16-16-16-36 to 15-15-15-36 the frequency drops to around 3422-ish. I've never had this on previous motherboards but this is my first Gigabyte. I can set frequency to 3600, up the dram voltage to 1.4v and IO and SA to 1.27 so no shortage there but I can't tighten timings. Any ideas where I'm going wrong?
28 Sep 2018
My Pro does the same. On the pro this was related to the trfc timings. If I went too low, the frequency would drop. Same with Cas.
Try to relax your tRFC while keeping 15-15-15-36.
On the whole RAM overclocking on the Gigabyte boards isn't a great experience.
3 Oct 2007
London, UK
Cheers for reply. Yeah I watched Buildzoids vid using my board and he says it overclocks ram well but with 4 sticks not 2. I'll give that a try though.
3 Oct 2007
London, UK
gigabyte test more with 4 kits rather then 2 like asus does, or prioritises .
I'm tempted to buy another kit and make it up to 4x 8gb. It does seem a little extravagant as I've not found a game yet that that is leaving my system short of ram. Having 11gb of vram obviously helps.
Glad! mind sharing a screenshot of your timings after you're done tweaking?
No worries :)
22 Aug 2009
I've got a waterforce z390 for a new build, I've posted a thread here about a weird USB issue I'm having
https://forums.overclockers.co.uk/threads/strange-issue-with-forcefeedback-on-new-build.18853506/
However I thought it worth asking in this thread if there are any known issues with USB on these boards as I'm scratching my head as to why a forcefeedback wheel which works fine on another PC will stop working after a few minutes on this one.
Regards
Fred
I am 99% confident that this situation was caused by the RGB Fusion software, or more precisely a process it installs.
Man of Honour
12 Jul 2005
Aberlour, NE Scotland
Which board because this thread covers all of the Aorus boards? The biggest problem with the Gigabyte boards for me is the awful bios. I came for having Asus boards which are widely accepted as having the best bios but with the reduction of quality and features yet charging more for their boards I jumped ship to Gigabyte only to discover the bios is terrible. Don't get me wrong, they are cracking boards and UK RMA is a bonus but they really need to completely overhaul the bios.
3 Oct 2007
London, UK
Yeah I came from MSI which had a great bios. I'd tinkered on a mates Z170 Gigabyte bios and found the bios on that to feel antiquated. Z390 is better than that but the layout is just not been thought through. Still the hardware is fantastic so its definitely with the purchase.
1 Nov 2008
Anyone got the mini ITX wifi one and overclocked an 8700k on it?
Toying between that and the Asus Z390 mini ITX one.
Not sure if one has any major advantages over the other?
1 Dec 2015
I had the z370 version, Z390 is greatly improved with better heatsink and VRMS! mine was getting toasty running 5.2ghz with 1.44v !!!!! around 100c VRMs when doing stress tests, 70c when gaming . Z390 will be a lot better !
Aorus use IR 3553 40A powerstages , 6 of them were as ASUS use NCP302045 45a again 6 of them. IR units are the better mosfet generally
also audio is better on the Aorus and believe has better wifi
customer service is miles better for Gigabyte then asus
1 Nov 2008
Cool, so to clarify you're recommending the Aorus over the Asus?
I'm glad you feel the Z390 is a big bump over the Z370, was actually contemplating a Z370 version too as they're cheaper. But if it's worth the jump I think I'll stretch for the 390
1 Dec 2015
4 phases vs 6 from z370 to 390.
old z370 uses OnSemi mosfet, both for hi and low (4C10 & 4C06). z390 uses IR units which are a single intergrated mosfet so you don't have two low and two Hi units to make one phase . Z370 Units are rated to 44amps roughly , also the PWM controller on the z390 version is better.
then audio & features
z390 aorus -
  • ALC1220-VB Enhance 114dB(Rear)/ 110dB(Front) SNR in Microphone with NICHICON Audio Capacitors
  • Intel® CNVi interface Wi-Fi 802.11a/b/g/n/ac, supporting 2.4/5 GHz Dual-Band
  • BLUETOOTH 5
  • 2x m.2
z370 aorus-
  • ALC1220 120dB SNR HD Audio with Smart Headphone Amp - no higher end caps and older ALC1220 chip
  • older Wifi chip and using Bluetooth 4.2
  • 2x m.2
z390 strix
  • same wifi and m.2 as aorus 370, same ALC audio as z370 aorus 7
personal experience , go the z390 ! even if its asus, aorus, msi, asrock etc
1 Nov 2008
Nice, thanks, will definitely go 390. Just realised they have Bluetooth 5 too, which I think I'll benefit from. I wear my Bose QC35 bluetooth headphones to watch and listen to media, with my current cheapo USB bluetooth adapter it loses signal really easily if I stray far from my desk, which is annoying.
Definitely edging towards the Auros at the moment considering it's £50 cheaper than the Asus.
