LG 34GK950G, 3440x1440, G-Sync, 120Hz
Suspended
14 Dec 2011
nVidia Question:
Does nVidia cards work with overdrive, using freesync on this monitor ?
Was on my way to get the AOC32G1, but just read that nvidia card wont work with freesync using overdive, and it makes the monitor useless IMHO; as it will get smear heaven and who want that :/
22 Nov 2003
Cardiff
Wonder what percentage of these monitors were returned under RMA and what under DSR. The ones returned under DSR will be resold as new or packaged into B-stock? I have a feeling that the ones that were returned under DSR will be then sold as new, which means somebody somewhere is getting previously returned monitor that has bad light bleed and or dead pixels.
Tough times, I am still very much interested in taking the gamble but the defect rate on these monitors seem to be quite high after going through this thread.
There is no way they could resell as new if it had been returned under DSR unless the original purchaser hadn't opened it. The sheer amount of sealed packaging within the box would immediately alert you to the fact someone else had opened it.
Caporegime
20 Jan 2005
Co Durham
From what people have said on here, most returns are just lobbed into the skip round the back of ocuk!!!!
Man of Honour
12 Jan 2003
UK
nVidia Question:
on the 34GK950F you mean? yes you can definitely still use the overdrive controls regardless of the graphics card vendor, and regardless of whether you activate Freesync/G-sync VRR
OcUK Staff
23 Feb 2015
Overclockers UK HQ
Monitors returned unopened go back into new stock. Those returned opened RMA/DSR for whatever reason, go into B-grade or back to the manufacturer if faulty.
Suspended
14 Dec 2011
nVidia Question:
Sorry wrong quote. I cant quote myself heh ..Runs and hide ..LOL!
Suspended
14 Dec 2011
Thanks Baddass, thats as it should be then :)
Good to know, but after reading up some more, I really want that G-synd model.Seems like freesync is way to far behind g-sync in every way (for what I have seen) so once g-sync allways g-sync I guess :D
Thanks again!
12 Jul 2010
Ordered one, will arrive on Saturday. Big purchase for me, hopefully it will be a fault-free but with my luck...*sigh*
Does seem like a perfect monitor currently. Will report here how it goes.
12 Jul 2010
Came in.
1 spazzing out pixel that is stuck from one angle and invisible from another.
1 dead pixel. Not a big deal, not that visible during normal use but quite noticeable when it has white background around it.
BLB minimal on default settings, essentially no BLB.
Downloaded new firmware but gaming still feels sluggish even at 144hz. Not sure what is the issue, why it feels that much less responsive than my current TN.
Decided to return it.
OCUK refuses to assist in returning the monitor.
DPD is giving only DPD Local options to return the monitor and "monitor" is on a restricted items list, so as I understand they will not deliver my monitor back to OCUK despite DPD delivering it to me.
Looks like I am going to have fun trying to return this thing. DPD guy on the phone said to give them a call on tuesday when sales team is back in working. Lets see what will happen then.
Edit: Has anyone here actually ever gotten an ultrawide without at least 1 dead pixel? Is it in the territory of miracles or myths?
22 Nov 2003
Cardiff
Got my replacement F yesterday - all set up and working perfectly.
About the same BLB as my previous one, bottom left is most noticeable. No dead pixels. I'm glad I settled for a swap out rather than a refund and purchasing a different monitor (which I almost did!).
5 May 2019
This is what my new 34gk950f looks like:
IPS glow (a bit exaggerated, but this is what I see on black backgrounds during normal use)
BLB
Photos were taken at brightness level equaling 17. BLB is hardly noticable, however glow takes like half of the left side. I rather don't see it on darker images (but not completly dark), but when screen turns black, it doesn't look nice. The bad thing is that it is visible from normal sitting position, let's say 70-80 cm away from the screen. In games it doesn't look that bad, for example in metro exodus it was noticable but not that horrible. In LOL I see it only on loading screen.
Also, I had some problems with brightness flickering on white backgrounds, but switching off "SMART POWER SAVER" (or something like that) option solved that. Beyond that I have no complains. I haven't found any bad or stuck pixels. LG program was laggy as hell (it was literally freezing my PC), but after reswitching USB port I finally managed to update firmware (which takes like half an hour). Colors are great but I don't see stunning difference between my old dell U2412m.
144 Hz of refresh rate is really good but it was more noticable on XF270HUA (which I returned because of other defects). Maybe because I sometimes don't reach 144 fps or maybe because this monitor is a bit slower than acer, I don't know.
Build quality is solid but it could be better for that price. Height adjustment is not as good as on my old dell but it does its job. Stand takes a lot of place on desk.
To be honest I don't know what to do. It is really nice monitor but for sure overpriced (for that money I can get almost 3 units of XF270HUA which is QHD 144 Hz IPS). That glow is really annoying and it ruins my experience a bit. From second side so many people receive damaged screens and so on that I doubt it is worth to play lottery and try again.
If you have any questions feel free to ask.
Stu
Stu
OP
19 Oct 2002
Wirral
Came in.
No problem with my Dell UW, no dead pixels. It is a big concern how many of these monitors appear to be shipped out with issues.
RSR
RSR
17 Aug 2006
I'm pretty much set on one of these now (F Model) to replace my Asus screens as I have been reading a lot of postive comments about them.
5 May 2019
By the way, do you experience small horizontal banding on darker colors? It is mostly visible on dark grey, where, from close distance, I can see few little strokes which have a bit different (but very similiar) color. It's hard to see it from normal viewing position tbh. Hard to take a photo
5 May 2019
On darker backgrounds (but not completely black) such as dark grey, dark red there are a lot of horizontal scan lines with a bit darker tone. They are hard to see from normal viewing distance (they absorb into the background), but when I increase the brightness or look on the screen from close distance they are clearly visible. On white background there is no way to see them.
I took a few photos (they are a bit exaggerated) and marked those lines with arrow. Please ignore that discoloration around the edges as it's mostly glow. I've updated firmware. Firstly thought that it's a problem with cable or GPU, even tried lowering refresh rate but it didn't help and I realized that it happens also when monitor is disconnected from GPU, so it seems to be a problem with panel.
https://imgur.com/a/9UhrFJD
The question is - is it normal for that type of panel (big curved IPS) or should I RMA it?
12 Jul 2010
A word of caution to those who will choose to return the monitor under DSR/CCR. ocuk WILL NOT arrange for a pick up through DPD business (business branch is the one that can actually deliver monitors), even if you offer to cover costs.
DPD Local does not deliver monitors. You can trick the system by filling it as something else or by just adding stuff like "IPS Gaming" but then you risking the delivery man refusing to honour the delivery and cancelling it. Also don't bother with £50 insurance as it does not cover monitors.
I had to go through UPS and it cost me around £30 to deliver it back to ocuk.
The monitor is amazing but once again, you need to be a lucky chap to get one without a dead pixel.
