Caporegime
Forget the Ryzen 3000 series, I'm saving my paper-round money for one of these:
https://www.anandtech.com/show/1430...ntier-supercomputer-cray-and-amd-1-5-exaflops
More money in AMD's coffers, nice
But can it play Crys....sorryForget the Ryzen 3000 series, I'm saving my paper-round money for one of these:
Processor Pentium - 800MHz or better
RAM 256MB
DirectX Version 7.0 or above
Touche!Crystal Maze has pretty low system requirements, it should do just fine IMO
Hard to tell from that snippet which target AMD hits. Current (0.93), Cascade Lake (1.0) or future (1.3), improving from current 0.87 AMD level. +15% IPC would bring it to 1.0That's interesting, it suggest they can't match Intel on clock speed or there is little if any difference in IPC Zen+ to Zen 2.
It's fine because there is no Zen 4. Thus:They should change its name to Zen 3 and leapfrog Zen 2 so we don't have this Ryzen 3k / Zen 2 foolishness.
Probably some nerdy reason why this isn't sensible.
There isn't any context around these statements in the Reddit post but I highly doubt these figures regard IPC. It's more likely overall performance Why?Hard to tell from that snippet which target AMD hits. Current (0.93), Cascade Lake (1.0) or future (1.3), improving from current 0.87 AMD level. +15% IPC would bring it to 1.0
Because it's only us nerds who even know the names Zen, Zen+ and Zen 2. The average consumer sees the perfectly sensible Ryzen 1000, Ryzen 2000, Ryzen 3000 (and corresponding Threadripper nomenclature). So there is no confusion to be had really.They should change its name to Zen 3 and leapfrog Zen 2 so we don't have this Ryzen 3k / Zen 2 foolishness.
When your electricity bill arrives you can guarantee a crisis of sorts!But can it play Crys....sorry
Yeah, but it's not as bizarre as Intel still being on 14nm for 14900K in a few years time.They should change its name to Zen 3 and leapfrog Zen 2 so we don't have this Ryzen 3k / Zen 2 foolishness.
Still happy with my Taichi, unless there is some major performance improvement from going X570 i'll stick with what I have.
So are RAM issues all resolved for Ryzen now? I read an article stating B-die was manufacturing has stopped now and will be replaced with A-die.
RAM 'issues' were resolved before Zen+ was released, it took a few AGESA versions to get it working well with lower spec'd RAM but I've not had many issues, and as long as you are not expecting to get 3600MHZ C14 on a set of £50 16GB DIMM's with a 2600 then you should be more than happy.
Generally 3000MHz and lower tends to 'just work', many 3200 kits will also be fine now. Using 4 sticks or higher speed memory is still a bit hit and miss and will probably require manual tweaking.
